Home > Td5 > New rear door prep |
Excellent solution to captive nuts. I have the Rivet tool if you need one |
20th Oct 2022 11:06am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
Cheers GB. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Oct 2022 11:07am |
No kidding, shelter is essential here in southern Denbighshire... |
20th Oct 2022 11:23am |
Ah, that's something at least but I don't think you'd regret beefing it up. When you come to assemble it after painting, I find that a rubber gasket between the carrier and the door to be a good idea to preserve the finish. I like Don's idea of reinforcing the whole door with chequer plate, but I guess you could always use plain ali sheet, 2-3mm, and cover it with vinyl if you wanted a slightly less agricultural look to it. Others have mentioned rivnuts, which are a great way to fix this sort of stuff, and stainless ones would be ideal for this application. I can also recommend one of these inexpensive tools to set them with: Click image to enlarge Hope that helps. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Oct 2022 12:04pm |
Cheers Darren. A gasket is a good idea, I have some thing neoprene rubber left over from when I did the chequer plate work a while ago. That does look quite the tool 1999 Defender TD5 110
20th Oct 2022 12:44pm |
Or a tool like
https://www.ebay.co.uk/itm/383145567965?ep...R5S_yOf-YA ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Oct 2022 5:41pm |
Thats pretty much what I have John. Works a treat and an incredibly useful tool to have in your garage
You just need stronger hands to use it than the one LRA posted up. |
20th Oct 2022 5:46pm |
Its all down to leverage! 1999 Defender TD5 110
20th Oct 2022 5:50pm |
There's a life lesson in that somewhere
20th Oct 2022 5:51pm |
Indeed there is.
Tonight I got the wiper motor hole drilled and ordered new rubber seal and new washer for the external part of the wiper motor. Next is a test fit and then the door card issue to resolve. Hopefully then into paint along with new door hinges Once back from paint its getting cavity waxed. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Oct 2022 5:54pm |
I've got one of those 90 degree tools too, but now only ever use it if I can't get the one pictured into position. They're really chalk and cheese, particularly if setting steel or stainless steel rivnuts. Darren
20th Oct 2022 9:17pm |
Completely agree LRA I have the same pair (basically) for pop rivets. As you say chalk and cheese.
21st Oct 2022 11:04am |
Tool and inserts arrived today. Just need some dry weather to work outside... 1999 Defender TD5 110
24th Oct 2022 2:00pm |
Also ended up ordering a new door lock, gasket and bolts. The old door lock felt like it was locked but would magically unlock itself 1999 Defender TD5 110
24th Oct 2022 2:04pm |
