![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 ![]() ![]() |
Yup - I am trying to figure out how to switch off this feature. I had a set of aux foglights fitted and connected via a relay to the factory fogs. Now though, whenever I turn on the indicators both the factory and aux fogs on that side light up. It was blinding drivers so I had to disconnect ther relay. I have tried a bunch of settings but cannot find how to disable. |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 114 ![]() ![]() |
I'm posting this again because, while I have not tried it, the description seems to match what you are trying to accomplish:
Are you referring to fogs as corning lamps? Try: MultiCAN-784 Front Fog Funtionality Front Fog and CL I'm assumig CL means Cornering Lamps. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Thats a turn lighting feature - not fogs, its useful. on the rr is a moving light. Been on LRs for years. Mike |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3019 ![]() ![]() |
l think it's a silly feature on cars.
ls there a setting in the CCF to turn it off with the GAP tool? |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
Try looking up 2 posts and you can tell us if it works Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
l'll try it tomorrow and report back
Vidoq Member Since: 05 Oct 2023 Location: Doha Posts: 4 ![]() ![]() |
Has anyone found how to activate video in motion?
249 - always allow video didn't work for me (( |
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 36 ![]() ![]() |
You need to set the MultiCAN577 SpdoCalPercentScale to the right scale.... If MultiCAN-838 was set 2.0% --> MultiCAN577 must set 2.0% You need to set also the MultiCAN575 SpdoCalkmhOffset to the right value... If MultiCAN-838 was set +0km/h --> MultiCAN575 must set to +0km/h |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 30 ![]() ![]() |
I was already happy with living with the speedo offset to the cruise set speed.... And then someone came along and solved it!! Thanks Brulz
PeteSkeet Member Since: 05 Aug 2023 Location: Houston Posts: 8 ![]() ![]() |
Does anyone know which specific option(s) in the CCF need to be changed to enable paddle shifters?
I have JET Pro now and can see all CCF options but I'm not sure which to change and I don't want to experiment too much. Thanks! |
I have the paddle shifters on mine but they were enabled by Hunters Prestige via Pathfinder, the only changes I can see from my CCF previous to having them enabled is
MultiCAN-536 GearboxPaddlesInDrive change to Active in Drive MultiCAN-537 SWSGearSelectors Change to Fitted This should also give you an option in Pivi to choose whether to be able to use the paddles in sport or drive/sport. BUT, I had tried these settings before Hunters activated it and I couldn't get them to work so there may be another setting which isn't accessible to the IID tool yet. Let us know how you get on ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Figured it out finally with the help of this other discussion!
https://www.defender2.net/forum/topic90062.html You were right, those were the 2 options that enabled the shifters in the CCF, but as someone else had mentioned previously in this thread, the DADC needed to relearn the new CCF changes for the paddle shifters to become active (they were discussing the parking assist but the same idea applies - both need DADC to relearn the CCF). The link I provided above helped walk me through how to get the DADC to do it's thing using the 72hr copy of JET Pro. Thanks again for everyone's help! Paddle shifters now working. Still need to play around with the software a bit more to get parking assist working. |
This did not work for me, l ended up with an "emergency braking not available" "2wd only" and the cruise control wouldn't engage. l put the settings back to original and the faults cleared. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
You would most likely need to also make DADC to relearn the CCF changes which you cant do with GAP tool yet, only with Jet Pro software MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
