![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 63 ![]() ![]() ![]() |
So the car was back to normal this morning so I tried again to activate dynamic mode. Did it correctly locking car and waiting and then rebooting the pivi. This worked and I got the dynamic function and menu. However there was something off with the car. I went for an hour long drive and it was mainly the rpms that seemed high. Regardless of drive mode. At my destination I restored the ccf to stock. Drove back and all worked fine.
The rpms was over 3000 at 140kmh after the ccf change. Compared to 2500 when restored. Both in Comfort mode. Quite odd. Anyone else experienced something similar? I know the car got an update or patch or something concerning the drivetrain just before delivery a week ago that was released that same day. There will apparently be a recall or whatever it’s called regarding all p400e to get this update. Could this be related? Won’t be doing anymore tinkering with the ccf in my car for now anyway. 😐 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2943 ![]() ![]() |
Yes l would definitely stop trying to activate "Dynamic" mode as your Defender clearly doesn't like it.
Nothing to stop you doing some of the other changes that are possible though. |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 51 ![]() ![]() |
``mmbanf wrote:
atldef110 wrote: I found a new feature today - Activate Park Assist EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) Have anybody able to activate Adaptive Cruise Control yet? Can anyone with ACC send me their CCF? hi, very interesting!! thanks for sharing. have you tried this and it works without errors? Thumbs Up `` I tried the parking assist the weekend. It worked perfectly, as in, the car finds parking spots and parks itself. Amazing. Yes I also get the brake warning and 2wd warning. Interesting, when I reset all the settings and restarted the car, everything worked perfectly with no warning, and park assist, until the next restart and then park assist disappeared. I suspect when GAP work out the ACC, all the other options, such as ATPC, TR2 and Park assist will all work at once. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
With regards to Park Assist I notice that LR Chip, which have just started offering activations in the UK, have the park assist option as coming soon so it may not be straightforward doing it via Pathfinder also
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
TCOV Member Since: 13 Oct 2023 Location: Houston, TX Posts: 1 ![]() ![]() |
Did Patrick get back to you on how to resolve? I am receiving the same message. Just picked up my2024 110 P400 Xdynamic SE. I am also having the same issue with incontrol. |
Make sure you are using the latest version of the app and make sure you have updated your firmware on the tool to the latest version, if the problem persists drop Patrick a line at gapteam@gap-diagnostic.com although it may be Monday before you get a reply
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Just received mine from Steve (thank you for all the help Steve) and just wanted to thank everyone on this thread for their contributions. It’s already helped me change a few settings.
It will definitely be traveling with me on my adventures. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
vcrabz Member Since: 05 Jan 2023 Location: Prague Posts: 7 ![]() ![]() |
can somebody with defender MY24 please post full CCF? thx
adnan_u88 Member Since: 21 Feb 2023 Location: Bolton Posts: 8 ![]() ![]() |
I had the same issue for MY24 - CCF Version Not Yet supported. Once I changed to beta firmware (build 3509) it seemed to work okay.
Since then there has been a Pivi update, just tried to make some other ccf changes today and its failing to upload the ccf changes. May need to change the firmware again? |
Philipp1601 Member Since: 17 Feb 2023 Location: Borken Posts: 23 ![]() ![]() |
Patrick helped me with my CCF upload problem.
It was solved by using the last beta and to have the car in a state with ignition on but engine off. Incontrol was solved by JLR, too. Unfortunately they reset the whole car again. So I lost my third party activated ACC again and had to reactivate it. So try to have the car fully incontrol activated before changing CCfs. One of the problems was that I wanted to use my standard email account which is related to my web hosting account with ionos.de. I had to use my iCloud account for incontrol to work. Greetings Philipp --------------------------------------- MY24 Defender 110 XS-Edition D250 Stealth Mod MY07 VW Multivan T5 Sport Edition D5 MY12 Mini R55 Cooper Works MY00 MB SLK 320 R170 Designo MY21 KTM 690 SMC-R |
brucehun Member Since: 04 Dec 2012 Location: Johannesburg Posts: 24 ![]() ![]() ![]() |
I received my gap tool and set up with no issues.
Ccf I changed which don’t work on ‘23 110 HSE although enabled: 1. Wifi hotspot 2. Stop/start 3. Tow assist 2 Dynamic mode, configurable TR, seatbelt reminder all good. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 243 ![]() ![]() |
They should work after a few reboots of pivi pro and restarts of car / lock and allow car to sleep
Thanks, will try that
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 172 ![]() ![]() |
Hi everyone,
I've already done the experiment... the vxdiag vcx +hdd jlr data tool works for the basic characteristics of the vehicle, for example I managed to calibrate the headlights after updating the matrix, then you can bleed the brakes with the guided procedure, many small things. but don't talk about ccf, being an offline connection it doesn't read vbf files, so no ccf editor........ I bought it because I use it and I have it. very happy with the gap tool, given the difficulties in activating acc and tr2, I wanted pathfinder to work on the DADC ecu and be able to set: learn central configuration, on the ecu functions. unfortunately vxdiag doesn't let you access the ecu functions, so nothing new. ![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
