![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
wlaughto Member Since: 19 Dec 2022 Location: Sydney Posts: 5 ![]() ![]() |
yes, same with mine. I wonder if this accounts for the discrepancy in the speedo - seems to be out a bit. |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
There is no difference in overall diameter between 19” and 20” (ignore offset and width, just used the calculator for tyre measurements)
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1427 ![]() ![]() ![]() |
It looks like there was an update to the app last night, but any changes must be under the hood so to speak as the ccf reading is unchanged when compared to the last update. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks to everyone who has contributed to the thread. I successfully ran some updates this evening including dynamic mode (with the red gauges).
Only thing I see is that I can’t select dynamic mode using the rotary dial after pressing the button to select modes. I have to physically press the touchscreen. Is this normal? ![]() Click image to enlarge ![]() Click image to enlarge |
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 ![]() ![]() |
Yes, I think that's normal, i.e., mine behaves the same way. It's also like that for Auto.
Do you have a 2023? I have a 2022 with the full digital display cluster and cannot get the red gauges. I get the red interior lighting, etc., but no gauges. We have a 2023 with hybrid analog/digital cluster and it does get the red gauges. I'm wondering if the red gauges in the cluster is only for 2023. |
Yes it’s a MY23. It’s was built in July just before MY23.5 came into production.
Yes that's how it works, you can't select it with the dial, also jealous of your red dials
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I was surprised Dan when they turned red. Fully expecting them not to. Sorry!!
Has anyone tried the engine power setting. Obviously most likely too good to be true but I was thinking that it should be possible to change it to a 300 given that software is the only difference. |
Let us know how you get on
![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Ermmm 😳 I did change it to 300/700 earlier and went for a drive. No faults came up but it’s so icy I couldn’t tell if it was any different. But it didn’t blow up
![]() ![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Would you mind sharing the advanced tow assist option settings? I have the electronically deployable towbar and would like to enable tow assist. Cheers! Adam. |
That goes for me too, I must have missed your post as I have been trying to get the advanced tow working also without success.
dakluck Member Since: 20 Jan 2023 Location: San Diego Posts: 8 ![]() ![]() |
getting in on this thread, super useful.
I did a quick diff w/Forza's dump (we are both MY20 L663) and found that the only diff I could find related to ATPC was this one. Interesting. If anyone wants to send me their dumps, I'd be happy to start aggregating diffs. Mine is current as of B2936-71. Interestingly the Dynamic mode codes didn't work for me, so still lots to learn. |
