![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
emariu Member Since: 12 Jun 2023 Location: Calarasi Posts: 12 ![]() ![]() |
thank you
oboe Member Since: 17 Jun 2024 Location: SDCA Posts: 3 ![]() ![]() |
Posting these for anyone looking... these are the configuration changes that successfully enabled me to upgrade from base LED headlamps to Premium LEDs... following Simon's videos from PowerfulUK got the headlamps installed but the folks at IIDTool got me the CCF configurations to make it work! Thank you!
MultiCAN-471 MainBeamFdbkMech BCM detects faults directly (0x8) MultiCAN-482 FntSdMkrDrvMech Driven via BCM (0x8) MultiCAN-679 HeadlightsVariant Headlamp_Variant_Mid_C (0x6) MultiCAN-750 High Beam Lights Not fitted (0x10) MultiCAN-814 Laser High Beam Menu Independent Laser setting (0x4) Unsure of this one; MultiCAN-858 Fog Lamp Location Bumper Lamp Module (0x30) |
Akmpro777 Member Since: 25 Jun 2024 Location: Estonia Posts: 5 ![]() ![]() |
Can you disable this annoying thing for EU-based cars "Driver assistance resets to High" with Gap iiD?
If yes maybe someone can point me to where this is located. Basically want my Driver Assistance to remain at "Custom" after I restart the car. Thanks! |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 22 ![]() ![]() |
Yes you can do it. I have to say I'm no expert on this but I changed it and it works for me.
MultiCAN-889 GSR2 EU Market Ft GSR2 Country Changed it to Non GSR2 Country Obviously I don't know what the potential implications are. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1430 ![]() ![]() ![]() |
Great find Bobbobbobbob and thanks for sharing, I'll add it to the list
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks! Does it still show the "Driver assistance mode will reset to High upon vehicle restart" warning or this also completely disappeared? |
It still shows the message but remembers the last setting
Received my iiD tool today and can confirm the following:
1) Stop Driver assistance resets to High MultiCAN-889 GSR2 EU Market Ft Change it to Non GSR2 Country Works perfectly. After restart stays at "Custom". No more annoying sounds. 2) Remember auto start/stop settings MultiCAN-566 MHLastUserMode = Enabled Doesn't work yet (d300 2024 model, eu specs). Will report in a few days, need to play around with resetting Pivi etc. |
Glad to hear the driver assistance one works
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2982 ![]() ![]() |
What's "Driver Assistance" l don't see this message on my 2022 D250
ls it the collision avoidance and lane departure etc? I can access these in the menu but they always reset to "standard" when l next use the vehicle. To be honest l would like the collision avoidance to remember l have turned it "off" as it's nearly caused an accident twice when lt activated unnecessarily. |
You don't see it on your MY2022 because it only started appearing on MY2024 onwards due to new legislation. Cheers Ian
Does anyone know if selecting the above with the GAP tool will also allow the vehicle to memorise the collision avoidance etc settings?
Update on the Start/Stop issue: Not sure what exactly did the trick but it works perfectly now! So after I changed the MHLastUserMode = Enabled - the car was left alone for around 12 hours. After I started the car the Auto Start/Stop was on as usual. I turned it off, did 2 Pivi resets while the engine was running and after that pressed the seat memory button to remember the seat setting (m + 1 in my case). Step by step: 1) Connect iiD 2) Disable start/stop 3) Change MultiCAN-566 MHLastUserMode = Enabled 4) Leave the car for 12 hours 5) Start the car 6) Disable start/stop 7) Reset Pivi ![]() 9) Press seat memory M + 1 (double check that the auto start/stop is disabled) 10) Turn off the engine. Open the driver's door. Close the car. 11) Start the car And the car starts with start/stop disabled. Hope this helps! |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 55 ![]() ![]() |
hello, did you manage a park assist?
i tryied Park assist settings Activate Park Assist EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears) Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error. and checked also MultiCAN 658 still nothing. An icon does not appear on my screen. Any trick? How long did you let you car locked? thank you |
