Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 10 of 109 <123 ... 91011 ... 107108109>
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
PM me your full ccf list and I'll have a look. I made an earlier change that gave me that error. I may be able to spot it.
Kyle 20MY Defender 110 Fuji White
Post #973252 2nd Dec 2022 8:01pm
pllr
United States
These are the three settings that were different between the 2022 w/ACC and 2023 w/o ACC, i.e., this is how the 2022 w/ACC is set from the factory. Every other related setting (e.g., other 712) were already the same.
MultiCAN-580 PTCruiseFitment
ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display
Not Fitted
MultiCAN-809 ACC Stop Gap Setting
Fitted
Post #973264 2nd Dec 2022 9:04pm
umbertob
United States
pllr wrote:
Does anyone else have an incorrect tire size in their CCF file? In our 2023 with 18-inch wheels, it's correctly listed at 18-inch wheels with the right dimensions.
Our 2022 has 20-inch wheels from the factory, but the CCF file says:
MultiCAN-597 TyreSizeCorrnFac
255/65 R19 A/T TYRE
I suppose it doesn't really matter since I would have never known but for the IIDTool, but I'm wondering if my recommended tire pressures are displaying correctly in the dash display.
I attempted something like that initially by "correcting" the size when I switched to 18" wheels (not sure if it was in the above entry or another one in the CCF, it may have been MultiCAN-596) and the speedo was thrown off big time after the upload, even though it appeared to me that I had selected a more appropriate tire size... It showed me going 120 mph when I was really coasting at 70... Everything went back to normal when I knocked that setting back to the original default, but I just wanted to give you a heads up.
Tire pressure for all factory tires should be the same regardless of wheel size anyway (save perhaps for cars fitted with 22"), so as long as your speedo is accurate I would not mess around with those settings and leave them alone. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #973266 2nd Dec 2022 9:05pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Personally I think there may be still one or two settings that aren't available yet that need to be set to enable ACC, just like how I can't get TR2 to work yet. The tool/software is still in its early stages of Beta and I'm sure the team at GAP are working to make all these settings available to us. The last update brought 5 new settings and I'm sure each update will bring more each time. Also if you do something and it brings an unexpected result/fault let Patrick know by submitting a bug report Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #973267 2nd Dec 2022 9:11pm
umbertob
United States
Not Fitted
Fitted
MultiCAN-712 ACC Lead Car Distance Display is set as "Fitted" in my 2020 with factory ACC. The other two settings match your 2022's. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #973268 2nd Dec 2022 9:15pm
Hairy Dan
Just to confuse things
Not Fitted
This is set to not fitted on my car and I have acc with queue assist from the factory Cheers Ian
Kielder 4x4 Safari
Post #973269 2nd Dec 2022 9:20pm
pllr
United States
Thanks for that.
Hmm. I didn't change anything on the 2022 yet (mostly because I want the 2023 to behave the same way). Only downloaded the existing CCF file. So "MultiCAN-712 ACC Lead Car Distance Display" isn't respected by my car.
Different subject, but I was hoping to turn on mirror dipping in reverse in the 2023, like I have in the 2022 (and most cars in the last 15 years). I changed the settings to match, but nothing happened. I suppose it needs the "memory" functionality/ECU to do that.
Post #973270 2nd Dec 2022 9:22pm
zhihong.james
Canada
whiterdesign wrote:
Simon from Powerful has just put a video out using the gap beta tool to add an activity key to his new defender
Will definitely have to check that out. But the main issue is cannot buy the activity key since they are out of stock now.
Post #973273 2nd Dec 2022 9:46pm
Bob Heijnen
Netherlands
I receiver the IIDtool BT also and updated it. When connecting to my L663 it connects fine but the car config option does not show. Is there a setting I have to adjust? Help is appreciated.
Post #973304 3rd Dec 2022 11:17am
Hairy Dan
Have you asked Patrick to join the beta programme? Cheers Ian
Kielder 4x4 Safari
Post #973305 3rd Dec 2022 11:19am
Bob Heijnen
Netherlands
I did but not activated yet. Is it only accessible via beta?
Post #973307 3rd Dec 2022 11:32am
Hairy Dan
Yes you need to use the Beta app to access the car config etc Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #973308 3rd Dec 2022 11:33am
Bob Heijnen
Netherlands
Great, many thanks.
Post #973309 3rd Dec 2022 11:34am
Bob Heijnen
Netherlands
I have the beta app installed but still no car config option. Does the latest updates from the car prevent it? Any other tips?
Post #973337 3rd Dec 2022 6:47pm
Hairy Dan
Hi Bob have you tried opening Testflight and starting the app from in there
you should have version 4.1.0 (105) Cheers Ian
Kielder 4x4 Safari
Post #973350 4th Dec 2022 12:35am
