Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 90 of 108 <123 ... 899091 ... 106107108>
Looneyfitter
Anyone know what code makes the 4x4 camera appear/disappear? I've altered a. Code when installing my deployable. Tow bar and it's disapeared. All other cams work. Though.
Cheers.
Post #1036397 3rd Jun 2024 5:22pm
malibu
Australia
Has anybody managed to get the Air Quality and Ionizer installed? I have found out how to turn on the screen, the next step is to find the sensors.
Post #1036515 5th Jun 2024 3:20am
fubar
Australia
Would love to know what you did to get as far you have on the ion filter -----
Larry Junior: L663 MY23.5 D300 110
Larry Senior: Series 3 Stage 1 V8 109
Post #1036520 5th Jun 2024 7:15am
malibu
Australia
I changed 752 Enhanced Filtration to Enhanced Particulate Filter and sensor fitted and soft button fitted
If you make this change you will see the Air quality screen. If you go into Faults in the GAP tool, it will mention the sensors that are missing. I am not having much luck finding the part numbers for the sensors. I suspect it may require replacing the external temp sensor with one that also measures air pollution, or maybe it is an additional sensor.
The next setting I will change is 510 Airionizer.
Enjoy
Post #1036522 5th Jun 2024 7:22am
fubar
Australia
Thanks mate. I will give that a go on the weekend. I have the L663 so hopefully will be the same as yours. -----
Post #1036554 5th Jun 2024 11:04am
Emp
Germany
Hello,
I am expecting an MY25 and unfortunately it no longer has Wade Sensing as standard. However, I assume that they are identical mirrors and that I can activate it via my G4 tool. Does anyone know what settings are required?
Thanks to everyone for this impressive collection of information in this post.
Post #1036620 5th Jun 2024 11:39pm
DefenderMidlands
Wade sensor settings include the following, whether there is anything else to make it work I am not sure, someone needs to try it on a MY25 car
• EUCD-209 Wade Sensing
(0010) Wade Sensing Fitted - Manual Display
• MultiCAN-755 Wade Prog Mode
Available for selection with timeout
• MultiCAN-759 Ultrasonic Sensor Fit
Rear Front Flank + Wade
• MultiCAN-796 Ter Wade Select In FCPB
Rotary used for selection within touch screen MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1036631 6th Jun 2024 7:21am
DefenderMidlands
Wade sensor settings include the following, whether there is anything else to make it work I am not sure, someone needs to try it on a MY25 car or a car without WADE sensing, I would presume the hardware is standard in all defenders although I believe wade sensing closes off some vents to stop water ingress which may not already be fitted to all cars
Post #1036632 6th Jun 2024 7:21am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You would need to make sure that the mirrors have the wade sensing sensor fitted, the parts catalogue lists the mirrors as "with water wading equipment" and "less water wading equipment" Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1036635 6th Jun 2024 7:38am
Emp
Germany
Thank you very much. I don't think any MY25s have been delivered yet, but hopefully I'll try it out soon.
Post #1036636 6th Jun 2024 7:39am
Emp
Germany
Oh damn. I didn't see that.
I just saw in the internal order document that it's mirrors without modifications like my MY24 order where it was still standard.
If it's not installed, it's probably not worth retrofitting mirrors.
Post #1036637 6th Jun 2024 7:42am
Defendit..
Netherlands
Enjoy
Did you also change:
EUCD-150 Air Quality Sensor
Without Air Quality Sensor to With AQS. ? No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1036649 6th Jun 2024 9:00am
Hairy Dan
This is what the mirror underside looks like with the wade sensors, they are really just like a parking sensor.
The mirrors for cars with wade sensors are approx £500 each! My car has them fitted as standard but I can't say I've ever used them as they are really quite pointless, you need to know the depth of the water before you drive into it. Confused Cheers Ian
Kielder 4x4 Safari
Post #1036679 6th Jun 2024 1:45pm
LR Nuts
^^^^^^ agree with your comments.
I have just checked ...... and yes I too have all three on the underside of BOTH mirror housings, as standard.
Surprised
Post #1036689 6th Jun 2024 2:47pm
Emp
Germany
It is inexplicable why they have removed it from the standard in Germany. Now you can only get it with the off-road package and so you are tied to the tires there.
Well, I'll do without it if I have to. It's just a fun feature and we all like to have fun. But not at any price.
When I have my MY25 HSE, I'll tell you which mirrors are supplied. Until then, I'm still hoping a little Wink
Post #1036721 6th Jun 2024 7:02pm
