Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2690 |
There’s a commodity code for ‘vehicle diagnostic device’
4th Mar 2024 6:58pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
There is a setting for Automotive diagnostic device and if you put it down as warranty return, value £5. Did Patrick ask you to put it down as a gift? Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
4th Mar 2024 11:25pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 |
I didn’t set dynamiclitemode and everything works fine, touch and knob. I haven’t heard that dynamiclitemode does anything. Lack of it has certainly not hurt my dynamic or TR activations. Last edited by pjeski on 9th Mar 2024 2:12pm. Edited 1 time in total |
7th Mar 2024 9:26pm |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 21 |
Got my defender today, anyone know when the G4 is going on general sale?
9th Mar 2024 12:11pm |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 30 |
Same for me. Everything is there except the start button is grayed out and cannot be pressed. Activated today with the G4. 23.5MY Defender 110 D250 HSE |
9th Mar 2024 6:16pm |
coda0 Member Since: 07 Sep 2023 Location: Clearwater, Florida Posts: 5 |
Same for me. Everything looks correct except the "Start" Buttons is greyed. out.
9th Mar 2024 9:07pm |
When I activated configurable terrain response, it took a full day for the choice to show up on the PIVI screen, even after two PIVI resets, though it would show up on the IDD. Scrolling too it chose comfort. The next day, all working as should be. Maybe the park assis is the same way.
9th Mar 2024 9:26pm |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 |
Someone tried to make a D300 out of a D200 already?
10th Mar 2024 12:14am |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 |
Delete - duplicate post Last edited by chpsk8 on 10th Mar 2024 4:01pm. Edited 1 time in total |
10th Mar 2024 4:00pm |
I tried parking assist yesterday. No luck. I have the steering wheel on the PIVI. I can select the steering wheel and it brings me to a new screen where it is actively scanning for parking spots. It asks me to stop and select a spot. I can toggle between parallel and bay parking. I can select the parking spot. I cannot select start I did have luck with ATPC. It takes two pushes on the button to activate, but it does work. I was able to program ACC. I did have to let it sit to clear errors, but it works without error now. Anyone have any other codes to try on the parking function? I have a 2023.5 110 P300 |
It's supposed to. Last edited by pjeski on 10th Mar 2024 4:33pm. Edited 1 time in total |
10th Mar 2024 4:33pm |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 238 |
Two presses of the hill decent control BUTTON is correct to activate ATPC MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
dsstephens Member Since: 06 Jul 2022 Location: Hartwell Posts: 16 |
<double> 2020 SE First Edition
2004 Disco2 1986 110 V8 1971 Series IIa 88” Last edited by dsstephens on 11th Mar 2024 9:26pm. Edited 1 time in total |
11th Mar 2024 8:00pm |
Got the G4 this weekend and activated. Connected and read. noticed 3 things
1) engine is running, but it is flashing red letters at the top indicating <ign> (need to verify exact wording). 2) when connected, it threw a "emergency braking not allowed" error without any intervention 3) tried changing 007 setting as a simple one and the ACC as not so simple; update failed. tried restoring backup, update failed (even though it hadn't successfully written first). now it throws ATPC and HDC not available errors. Will let it sit and go out and try it all again. open to any suggestions. 2020 SE First Edition 2004 Disco2 1986 110 V8 1971 Series IIa 88” |
11th Mar 2024 8:01pm |
