Home > General & Technical (L663) > Bonnet latch
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Bonnet latch
Hi all
Can I just pick your brains? Both the bonnet latch catches move when I wiggle them. Is this normal?
It’s the black part with the black nut on that moves…
Jim
Post #957462 6th Jul 2022 3:03pm
AndrewS
Cant answer your question right now, however my 400X went in several times with bonnet opening issues. 130's have feeling's as well you know Smile
Post #957466 6th Jul 2022 3:47pm
GrouseK9
United States 2016 Defender 110 BMW M52 2.8i Petrol CSW Auto Indus Silver
Yes, that's not normal. Try tightening it a bit.
Post #957472 6th Jul 2022 4:28pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
No not normal, mine are solid Thumbs Up Or yours could be normal and mine are incorrect Wink Neutral Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #957515 6th Jul 2022 10:11pm
jim4244
Hmmm….. I can feel a call to the dealer coming on 🧐
Jim
Post #957576 7th Jul 2022 11:56am
camelman
Can't you just fasten it up?
Post #957577 7th Jul 2022 12:01pm
jim4244
There’s no more turns left on the black nut to tighten it. There’s around about 5mm of play to both sides?
Jim
Post #957699 8th Jul 2022 12:31pm
Nuclear Nick
I noticed that on mine too. Both hoops a little loose but not as much movement as yours. I decided that it’s probably designed that way, maybe to allow some ‘self alignment’. The catches were all dry so I gave them a thin smear of grease while I was there.
Post #957706 8th Jul 2022 1:47pm
FLwolverine
United States
Mine moves too. No worries, just leaving as is.
gary
Post #958238 14th Jul 2022 2:45am
RobN
United States
Just checked my '22 D90 P300. Both of mine have the same wiggle. Weird.
Post #958239 14th Jul 2022 2:49am
