Home > General & Technical (L663) > Bonnet latch |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Cant answer your question right now, however my 400X went in several times with bonnet opening issues. 130's have feeling's as well you know
6th Jul 2022 3:47pm |
GrouseK9 Member Since: 09 Aug 2021 Location: Austin, Tx Posts: 16 |
Yes, that's not normal. Try tightening it a bit.
6th Jul 2022 4:28pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1414 |
No not normal, mine are solid Or yours could be normal and mine are incorrect Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
6th Jul 2022 10:11pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 773 |
Hmmm….. I can feel a call to the dealer coming on 🧐
Jim |
7th Jul 2022 11:56am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3370 |
Can't you just fasten it up?
7th Jul 2022 12:01pm |
There’s no more turns left on the black nut to tighten it. There’s around about 5mm of play to both sides?
Jim |
8th Jul 2022 12:31pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 282 |
I noticed that on mine too. Both hoops a little loose but not as much movement as yours. I decided that it’s probably designed that way, maybe to allow some ‘self alignment’. The catches were all dry so I gave them a thin smear of grease while I was there.
8th Jul 2022 1:47pm |
FLwolverine Member Since: 27 Jun 2022 Location: Florida Posts: 5 |
Mine moves too. No worries, just leaving as is.
gary |
14th Jul 2022 2:45am |
RobN Member Since: 10 Jan 2022 Location: Los Angeles Posts: 8 |
Just checked my '22 D90 P300. Both of mine have the same wiggle. Weird.
14th Jul 2022 2:49am |
