![]() | Home > General & Technical (L663) > Bonnet latch |
Cant answer your question right now, however my 400X went in several times with bonnet opening issues. 130's have feeling's as well you know
GrouseK9 Member Since: 09 Aug 2021 Location: Austin, Tx Posts: 16 ![]() ![]() ![]() |
Yes, that's not normal. Try tightening it a bit.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
No not normal, mine are solid
![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 922 ![]() ![]() ![]() |
Hmmm….. I can feel a call to the dealer coming on 🧐
Jim |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
Can't you just fasten it up?
There’s no more turns left on the black nut to tighten it. There’s around about 5mm of play to both sides?
Jim |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 297 ![]() ![]() |
I noticed that on mine too. Both hoops a little loose but not as much movement as yours. I decided that it’s probably designed that way, maybe to allow some ‘self alignment’. The catches were all dry so I gave them a thin smear of grease while I was there.
FLwolverine Member Since: 27 Jun 2022 Location: Florida Posts: 5 ![]() ![]() |
Mine moves too. No worries, just leaving as is.
gary |
RobN Member Since: 10 Jan 2022 Location: Los Angeles Posts: 8 ![]() ![]() |
Just checked my '22 D90 P300. Both of mine have the same wiggle. Weird.
