Home > Maintenance & Modifications > Drive flange bolts
Page 2 of 3 <123>
Grenadier
Phew, I was starting to feel very ashamed. Embarassed Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #948971 11th Apr 2022 8:38am
LET'S OFF-ROAD
LandRoverAnorak wrote:
Like Blackwolf, I used galvainsed cap head bolts on mine, with matching spring washers:
How have those enclosed wheel nuts fared, have they remained rust free unlike the genuine LR open ended steel nuts that go brown very quickly?
Post #988482 10th Apr 2023 12:51pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
“The typical helical spring washer … serves as a spring while the bolt is being tightened. However, the washer is normally flat by the time the bolt is fully torqued. At this time it is equivalent to a solid flat washer, and its locking ability is nonexistent.In summary, a lockwasher of this type is useless for locking.”
- NASA Reference Publication 1228 (1990) “Fastener Design Manual”
Clean the tapped holes with a slotted bolt or tap to remove debris then use a solvent to remove grease deposits from the hub holes and the bolts. Next put a blob of loctite 231 on each bolt, refit and tighten. When all are nipped tight torque per workshop manual.
Used to notice loosening of the drive flange bolts on our race 100" Tomcat - the rear axle when it had the Detroit locker was the worst culprit for this. Threadlock, torque and witness paint lines on each bolt saved a lot of hassle in the service park.
Post #988510 10th Apr 2023 4:53pm
Ianh
Ohhh MercianRover.... you have opened up this debate again Very Happy
All I can say is I have the cap head bolts plus spring washers and nothing has rattled loose to date, I think others like blackwolf have had the same experience as I over a longer period and many more miles.
The chief issue most experience is shearing the bolt(s) when attempting removal from the blind hole. This is attributed to using thread locker and / or detritus in the blind hole. Hence using spring washers instead. If you clean the threads , clean the bore and use low strength thread locker you may avoid the bolt shearing issue, but so far using the spring washer has worked ok for me.
An alternative could be to use a Nord-Lock washer, which would be my choice if I found the spring washers were not performing well, as drilling out a sheared bolt is a real PITA
Post #988516 10th Apr 2023 5:48pm
Poo-pooing spring washers is all well and good, but I have to observe that in 45 years of Land-Rover ownership I have never had a properly tightened drive flange bolt fitted with a conventional spring washer come loose, and nor, as far as I know, did Land-Rover in the fifty or so years that this was the firm's design approach.
On the other hand, I have had two (at least) snap on my Defender when they have been fitted with threadlock adhesive, usually when attempts are being made to remove them. The hassles this can cause are considerable.
I will continue to use spring washers for this application, others can make their own choice. Thumbs Up
Post #988518 10th Apr 2023 5:54pm
MercianRover
If it's the threadlocked bolts failing on removal then there's a problem with the bolts not the threadlock. Had the bolts bottomed out and jammed in the hole?
What grade and make were the failed bolts - inferior copies perhaps?
Post #988931 14th Apr 2023 12:16pm
I think that the failures are generally caused by the holes becoming plugged with surplus threadlock adhesive and/or gasket compound, the bolts then hydraulic lock before being fully inserted due to the gunk in the blind hole, and the tool with the tool then stresses them to yield trying to get them in. Then the threadlock cures and they shear when an attempt is made to unscrew them.
Post #988936 14th Apr 2023 12:41pm
TexasRover
You would think that if the spring washers were truly that useless everyone would have stopped using them, in the end it is an additional cost which either works and if it does not can be eliminated.
Post #988938 14th Apr 2023 1:18pm
hank
Mine has been on stainless cap heads for years... No problems yet > 110 XS Double Cab
Post #988943 14th Apr 2023 1:39pm
jimbo55
I think the biggest problem with threadlock is that people don’t know what product to actually use (there are hundreds of different grades that do different jobs) and they smear it all over the full length of the bolt and not just a blob which is where people snap the drive flange bolts.
As an engineer, if you want a washer to prevent the bolt loosening fit a nordlock washer, if you don’t then fit a plain/flat washer. Springs washers are things of the past and are pretty much useless as per Mercian rovers comment and as soon as the bolt becomes slightly loose the spring will loosen the bolt further.
A properly torqued bolt should not come loose, albeit that relies on the stated torques being correct,
I personally went for cap head bolts and nordlock washers without threadlock.
Post #988957 14th Apr 2023 2:25pm
hank
I saw this recently on the washer subject which I found interesting
 > 110 XS Double Cab
Post #988960 14th Apr 2023 2:46pm
BrickBox
https://rimmerbros.com/Item--i-RUC105200BPKBOLT 2008 2.4 110 Utility Station Wagon XS.
Post #988979 14th Apr 2023 4:43pm
I wonder what, on Planet Britpart, makes those "heavy duty'.
Post #988986 14th Apr 2023 5:57pm
Mo Murphy
I always use spring washers and no threadlock, torqued to 65nm . None have ever come undone or have sheared.
What I have found makes them come undone is stretching them by overtightening, then they just rattle out of their own accord.
50 Shades of Pennine Grey
Post #989014 14th Apr 2023 8:17pm
kenzle8a
I had a set as i was sent them by mistake, they turned brown in a matter of weeks, which was even more impressive as it was sat on the driveway the whole time.
Post #989023 14th Apr 2023 9:53pm
Page 2 of 3 <123>
