Home > Tdi > Cambelt Pulley System issues??
Page 2 of 2 <12
Oldowner
The revised bracket is a straight fit, you need two longer bolts than the originals from memory, but it is a long time now since I’ve fitted one.
The cheap Tdi timing tool kits from Amazon etc are very good, although you still need crankshaft pulley holder (ebay)
A proper MHH Torqueleader or similar is required to properly tension the belt.
Post #953000 19th May 2022 8:49pm
Mo Murphy
A set of pushrods and possibly some rockers.
Remove the rocker shaft and the rockers from it to check for cracks or breakage in the rocker shaft itself.
HTH
50 Shades of Pennine Grey
Post #953031 20th May 2022 11:22am
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Way ahead of you Laughing
Post #953033 20th May 2022 11:42am
Mo Murphy
Indeed you are 👍
Post #953034 20th May 2022 12:06pm
Jeebs
I plan on making some form of artwork out of the 8 bent pushrods……..
Post #953035 20th May 2022 12:08pm
Jeebs
Latest in my cambelt saga….
Once the timing case was open it would appear the belt had just snapped. Despite being a genuine dayco belt from Bearmach fitted less than 2yrs ago. It was perished and a bit grotty looking, no other apparent reason for failure.
However, the aux drive pulley had to have the bush burnt out to get it off and the aux belt tensioner had failed.
Am I right in thinking I need the following?
ERR2220R - Crankshaft Damper Assembly
ERR4708R - Aux belt tensioner
ERR5087 - Damper assembly bolt
I’m sticking a new water pump on for good measure whilst refreshing all the rest as seems the logical thing to do.
The good news is, fired up first turn.
Post #955585 15th Jun 2022 12:55pm
Jeebs
Double post in error
Post #955586 15th Jun 2022 12:55pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
How have you fired it up without a crank damper assembly and bolt fitted? That holds the bottom timing belt pulley in place.
Post #955589 15th Jun 2022 1:33pm
Jeebs
Old one back on, start up, turn off. Just to make sure the engine actually runs, given cambelt failed and has been stood for almost 14months.
Replacing as it’s been heated to get it out. Don’t fancy reusing it long term just incase.
Post #955593 15th Jun 2022 2:15pm
Page 2 of 2 <12
