![]() | Home > Tdi > Cambelt Pulley System issues?? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2285 ![]() ![]() ![]() |
A set of pushrods and possibly some rockers.
Remove the rocker shaft and the rockers from it to check for cracks or breakage in the rocker shaft itself. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Way ahead of you ![]() |
Indeed you are 👍
I plan on making some form of artwork out of the 8 bent pushrods……..
Latest in my cambelt saga….
Once the timing case was open it would appear the belt had just snapped. Despite being a genuine dayco belt from Bearmach fitted less than 2yrs ago. It was perished and a bit grotty looking, no other apparent reason for failure. However, the aux drive pulley had to have the bush burnt out to get it off and the aux belt tensioner had failed. Am I right in thinking I need the following? ERR2220R - Crankshaft Damper Assembly ERR4708R - Aux belt tensioner ERR5087 - Damper assembly bolt I’m sticking a new water pump on for good measure whilst refreshing all the rest as seems the logical thing to do. The good news is, fired up first turn. |
Double post in error
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 828 ![]() ![]() ![]() |
How have you fired it up without a crank damper assembly and bolt fitted? That holds the bottom timing belt pulley in place. |
Old one back on, start up, turn off. Just to make sure the engine actually runs, given cambelt failed and has been stood for almost 14months.
Replacing as it’s been heated to get it out. Don’t fancy reusing it long term just incase. |
