Home > Td5 > Dead Defender TD5 |
15th Dec 2021 7:05pm |
Yes you will have to code the ECU to your injectors. If you have not been able to get the codes from the old ECU then you will need to pop the rocker cover and read them off the injectors.
EDIT: and you will have to link to the alarm/immobiliser as well. |
15th Dec 2021 9:22pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Why? I think it the blue underseat header is faulty C0294, I’d be interested to see if you wiggle it will it start! Also check the white header joint bolted to the bulkhead as that controls everything you have missing. |
16th Dec 2021 11:08pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2777 |
l tried all suggestions, check the earths, the inertia switch, live feeds, etc and it made no difference
The RAC guy spent an hour on it and got nowhere The garage swapped the ECU for a known good one and it started instantly So l guess it's the ECU. They do fail without warning. |
17th Dec 2021 8:41am |
So, it was the ECU
l took the ECU to a guy who specialises in Defenders, he had a look at it and found a faulty resistor on the PCB. He replaced it and it's back in the Land Rover and working perfectly. I thought that was pretty decent of him, as he could have sold me a replacement ECU. He charged me £80 for the repair. l bought an ECU off him anyway for £700, to keep as a spare, and he waived the £80 repair charge on mine. So l've got a repaired ECU and a spare, the spare has been loaded with my injector codes and a remap, for £700 l paid nearly £400 for just a remap from one of the big companies a few years ago. |
17th Dec 2021 6:09pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Great result in the end.
17th Dec 2021 6:34pm |
good result with speeded turnaround around
17th Dec 2021 8:04pm |
Brilliant. Good result in the end
18th Dec 2021 1:09pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 928 |
Glad you got it sorted 👍
As a TD5 owner too its good to know there are sensible options out there for this! |
18th Dec 2021 1:48pm |
