Home > Td5 > Dead Defender TD5
Page 2 of 2 <12
dorsetsmith
Post #933721 15th Dec 2021 7:05pm
lightning
lf you fit a different ECU does it not need coding to your injectors before it will work properly, like on my Ford Transit Connect?
Or is it not an issue on the TD5
Post #933752 15th Dec 2021 9:06pm
geobloke
Yes you will have to code the ECU to your injectors. If you have not been able to get the codes from the old ECU then you will need to pop the rocker cover and read them off the injectors.
EDIT: and you will have to link to the alarm/immobiliser as well.
Post #933759 15th Dec 2021 9:22pm
NickMc
lightning wrote:
So it needs a new engine management unit.
Anybody know where l can get one quickly? It's a late Defender TD5
Part no. NNN50020
Why?
I think it the blue underseat header is faulty C0294, I’d be interested to see if you wiggle it will it start!
Also check the white header joint bolted to the bulkhead as that controls everything you have missing.
Post #933933 16th Dec 2021 11:08pm
lightning
l tried all suggestions, check the earths, the inertia switch, live feeds, etc and it made no difference
The RAC guy spent an hour on it and got nowhere
The garage swapped the ECU for a known good one and it started instantly
So l guess it's the ECU. They do fail without warning.
Post #933954 17th Dec 2021 8:41am
lightning
So, it was the ECU
l took the ECU to a guy who specialises in Defenders, he had a look at it and found a faulty resistor on the PCB.
He replaced it and it's back in the Land Rover and working perfectly.
I thought that was pretty decent of him, as he could have sold me a replacement ECU.
He charged me £80 for the repair.
l bought an ECU off him anyway for £700, to keep as a spare, and he waived the £80 repair charge on mine.
So l've got a repaired ECU and a spare, the spare has been loaded with my injector codes and a remap, for £700
l paid nearly £400 for just a remap from
one of the big companies a few years ago.
Post #934028 17th Dec 2021 6:09pm
landy andy
Great result in the end. Thumbs Up Thumbs Up
Post #934033 17th Dec 2021 6:34pm
dorsetsmith
Thumbs Up good result with speeded turnaround around
Post #934047 17th Dec 2021 8:04pm
geobloke
Brilliant. Good result in the end Thumbs Up Thumbs Up
Post #934102 18th Dec 2021 1:09pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Glad you got it sorted 👍
As a TD5 owner too its good to know there are sensible options out there for this!
Post #934105 18th Dec 2021 1:48pm
Page 2 of 2 <12
