![]() | Home > Puma (Tdci) > Strange red light |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Your key fob battery needs to be replaced Roaming around π³π΄π¨π
Tepidboy Member Since: 20 Dec 2018 Location: Cheshire Posts: 12 ![]() ![]() |
Oh good, you know that for sure? Iβll get a battery in it.
CR2032
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
follow the guide in the manual to change it or it could loose the coding DEFENDER 90 TDCI XS,
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 182 ![]() ![]() ![]() |
This is a good place π
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2275 ![]() ![]() |
The fob battery replacement procedure is needed if you have the old style fobs. If you have a late 2.2 Puma with the new fobs, which have the chrome strip on the side, you can just replace the battery without the need to follow the procedure highlighted above.
Note some older pumas have the new type fobs if they have had an alarm ECU replacement. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
I'm not sure that it is actually needed even on the older fobs. With my 2007 TDCi I changed the fob batteries several times before I even knew of the procedure by simply popping a new battery in the fob (in the house or in my office, well away from the vehicle) and everything worked without a hitch. It is entirely possible that I was just extremely lucky, of course.
You never know, but someone in LR who wrote the owners manual may have had a very dry sense of humour, put an unneeded random process in it for fob battery change, and is smirking every day at the thought of people like me following it. ![]() ![]() Actually I kind of like that thought ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Yep me too, on two defenders. All worked ok. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
Like Blackwolf never had a problem with just swapping batteries, never used a specific procedure. Defender 90XS SW
