Home > Puma (Tdci) > Strange red light
Tepidboy
Strange red light
This is really puzzling me.
When I unlock the defender and don’t start to the engine for say more than a minute, this red light remains on the dashboard throughout my drive.
Anyone have this problem or know why this happens?
This light is normally the one that flashes when the defender is locked to confirm it is armed.
Post #931162 25th Nov 2021 9:16pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Your key fob battery needs to be replaced Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #931168 25th Nov 2021 10:22pm
Tepidboy
Oh good, you know that for sure? I’ll get a battery in it.
Post #931196 25th Nov 2021 11:25pm
dorsetsmith
CR2032
Post #931197 25th Nov 2021 11:34pm
LR90XS2011
follow the guide in the manual to change it or it could loose the coding DEFENDER 90 TDCI XS,
Post #931210 26th Nov 2021 7:32am
dorsetsmith
Post #931214 26th Nov 2021 9:57am
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
This is a good place πŸ‘
Post #931289 26th Nov 2021 6:18pm
Ianh
The fob battery replacement procedure is needed if you have the old style fobs. If you have a late 2.2 Puma with the new fobs, which have the chrome strip on the side, you can just replace the battery without the need to follow the procedure highlighted above.
Note some older pumas have the new type fobs if they have had an alarm ECU replacement.
Post #931297 26th Nov 2021 7:01pm
I'm not sure that it is actually needed even on the older fobs. With my 2007 TDCi I changed the fob batteries several times before I even knew of the procedure by simply popping a new battery in the fob (in the house or in my office, well away from the vehicle) and everything worked without a hitch. It is entirely possible that I was just extremely lucky, of course.
Post #931322 26th Nov 2021 9:12pm
Ianh
You never know, but someone in LR who wrote the owners manual may have had a very dry sense of humour, put an unneeded random process in it for fob battery change, and is smirking every day at the thought of people like me following it. Rolling with laughter Rolling with laughter .
Actually I kind of like that thought Very Happy
Post #931324 26th Nov 2021 9:21pm
landy andy
Yep me too, on two defenders. All worked ok.
Post #931327 26th Nov 2021 9:38pm
discomog
Like Blackwolf never had a problem with just swapping batteries, never used a specific procedure. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #931383 27th Nov 2021 10:22am
