![]() | Home > My Defender > Swiss 110 Keswick 2.4 |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 ![]() ![]() ![]() |
Thank you very much Dinnu for the warning and tips. Yet another opportunity to use my Gorilla tape! I will redo that tomorrow.
As I am also fitting a Nakatanenga stainless bolt kit, I guess I will need to get some Duralac or Weicon pretty quickly. Is Duralac/Weicon different from the anti-seize pasta that Naka provides with the kit? I've read here all the cons regarding those stainless bolts, but also all good feedback amongst the community who did not encounter (yet) issue with SS. My current bolts are horribles and I need to replace them. Not easy to decide on a go/nogo... |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
Do not get me wrong, I like to use stainless fittings as much as possible too, and I have replaced all non critical bolts and screws to SS in my ongoing restoration. Any bolt that is critical, such as steering, suspension, braking etc, make sure you retain steel grade 8.8, 10.9 or what grade the original bolt is. That is because common stainless, such as A2/70 has lower yield than grade 8.8.
Given that the surface area of a couple of screws is very small compared to the surface area of the aluminium bodywork, the galvanic potential would not be so high, so it will not be that bad. However I still isolate, with barriers under washers. Keep in mind that paint is a barrier too. Speaking of washers and paint, I am one who thinks that washers are directional ![]() ![]() Re the anti seize paste supplied by Naka I cannot comment. I have never used it, and do not know its composition either. Mind you, I used Duralac on my restoration only capping rivets. I think those were the only thing that I could not isolate except by a good coat of paint - which probably the rivet can break through (I painted before assembly - unlike what JLR did). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
@ Dinnu: I also pay attention to washer mounting side
![]() As highligthed by ericvv in some of his posts I've ordered Weicon 26000045 anti seize paste, found in in anthracite color. ![]() Stainless bolts kit fitting on hold for now |
Absolutely not. To be honest, it tends to be a feature of relatively cheap washers but if using against a painted surface to prevent damage by the turning of the nut then it makes sense to fit them sharp edge up. There's an argument that if using them in some sort of mission critical application then you lose some of the contact area if fitted in that way but if it's that mission critical then you probably need a better quality washer anyway. The only place I can think of on a Land Rover that it would be relevant are the washers under diesel injectors, but of course they do have specific washers. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Probably I do pay the price of premium washers, and get cheap washers.. not the first time to find washers that look like had a bad index and the punch took away a bite out of it
![]() The way I use washers is actually opposite to the way circlips are installed on universal joints, were the sharp edge is used at an advantage to 'bite' better in its groove. I get what you say on the contact area. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Little trip today in the Vaud alps near Montreux in Switzerland, through a military shooting area on very scenic mountain road opened to public traffic only during the weekends.
A very narrow road ![]() Click image to enlarge And a small tunnel, with alternate traffic timeslots. One can go downhill only from 30' to 45', you better respect the timeframe because no way to deal with potential incoming traffic, and good luck to reverse within the non illuminated tunnel! ![]() Click image to enlarge Leading to a beautifull vista point on Lake Geneva ![]() Click image to enlarge ... I wonder which one is the most maneuverable, have not tried the tank, but it can not be worst than the Def ![]() ![]() Click image to enlarge |
Wheel arch eyebrows
Back from paintshop today, eyebrows and Wolf style rims in body color Keswick. I am happy with the result. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Still have to wait some more few days to let the paint on the rims harden before mounting my new winter tires. Current ones are Nokian Rotiiva, still looking good but way too old (2012!) and thus totally ineffective. After about 4 years a winter tyre must be replaced even if thread is ok as the compound is getting too hard and loose any ability to grip by cold weather, even worst on snow. New winter tires will be Nokian Hakkapeliitta LT3 in standard size 235/85r16 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10955 ![]() ![]() |
Great pic's, many thanks
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Love the colour coded arches. They look great. Looking forward to see pics with the colour coded rims.
I am doing a restoration on 88MY 90. I have the same rims (went for Goodyear MTRs) and had a dilemma, colour code the rims or not. At this moment I am keeping them white as planning to keep the white roof. Then will see when it is all together again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Only just seen this thread. Welcome to Defender ownership and the best forum
![]() ![]() You mention maneuverability, have you properly adjusted the steering stops? Even without et0 rims, properly adjusted stops can make a big difference. It did with me when I had standard rims. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thank you Clayton! |
Thank you James for your hint about the steering locks
![]() I've checked that and it appears that there is room for optimization. I currently have a 20mm clearance with the radius arm on right side and about 40mm on left side ![]() I will setup the clearance to 10mm (while 20mm is recommanded by the book) after I will have fitted the new winter wheels |
Wolf style rims 6.5x16 ET20.6 - Keswick green - Nokian Hakkapeliitta LT3 235/85r16
Wheel setup completed! Very very satisfied with the final look. In term of handling it is night and day with the fresh new tires comparing to the previous ones dated 2012. Winter is coming... Good to go ![]() Before ![]() Click image to enlarge After ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
The colour matched rims are perfect! A very classic look
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
