![]() | Home > In Car Electronics > Wiring loom Deutsch, DT Automotive Connectors |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
With cap just means there is a cap that retains the wire seal, see this document.. ('long cap' provides a lip to anchor a heatshrink boot to) https://www.te.com/commerce/DocumentDelive...%7FDT04-3P 1989 90 4.3 V8
2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
HoggR20 Member Since: 03 May 2021 Location: Reading Posts: 7 ![]() ![]() |
Great, just the information I needed and looking at the connectors I can see the difference now. I'm assuming using heat shrink makes the job tidier and potentially improved it waterproofing
Yes, heatshrink boots are the top tier for creating a sealed harness, you can use Raychem Atum with a 3:1 shrink ratio that will be large enough to fit over the connector but shrink small enough to seal onto the cable bundle. Much cheaper than boots also! 1989 90 4.3 V8
Brilliant thank yo
