![]() | Home > Maintenance & Modifications > MOT Failure |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Probably just the seal if the swivel isn’t pitted badly. 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
Nearside Front (HUB SEAL so this then
![]() Click image to enlarge (number 2) if this failed you see it Oil leaking or grease running down at the back brake disk as a side note check your axle breather pipe are not blocked (transmission) Nearside Front (HUB SEAL) [8.4.1(a)(i)] Mot computer program list that they have to used just as ( brake pipe corroded covered in grease or other material ) Phone mot inspector and check |
Sturdaa Member Since: 14 Jan 2015 Location: West Calder Posts: 23 ![]() ![]() ![]() |
Thanks, I'm hoping it's that seal - got a couple in the garage.
I'll give them a call to check |
