Home > Maintenance & Modifications > MOT Failure
Sturdaa
United Kingdom 2005 Defender 90 Td5 CSW Alveston Red
MOT Failure
I've just had the dreaded MOT failure phone call.
It's failed on "Oil leaking excessively from transmission Nearside Front (HUB SEAL) [8.4.1(a)(i)]"
Does this sound like a swivel replacement is needed, or just the hub oil seal?
The swivel was done less than 4k miles ago, so hoping it's not gone again already.....
Post #922947 27th Sep 2021 7:17am
familymad
Probably just the seal if the swivel isn’t pitted badly. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #922951 27th Sep 2021 7:22am
dorsetsmith
Nearside Front (HUB SEAL so this then
(number 2) if this failed you see it Oil leaking or grease running down at the back brake disk
as a side note check your axle breather pipe are not blocked
(transmission) Nearside Front (HUB SEAL) [8.4.1(a)(i)] Mot computer program list that they have to used just as ( brake pipe corroded covered in grease or other material )
Phone mot inspector and check
Post #922973 27th Sep 2021 9:05am
Sturdaa
Thanks, I'm hoping it's that seal - got a couple in the garage.
I'll give them a call to check
Post #922986 27th Sep 2021 9:53am
