Home > Technical > 200TDi losing power...
fearofweapons
Hello!,
Over the past year or so I have noticed that my 110 SW 200TDi has/is losing some power, especially towards the top end. While it used to be able to get up to and maintain 70 quite happily it now struggles and the slightest hill quickly sees me having to down shift.
The fuel pump is new. Is it worth getting the injector pump refurb'ed/buy a replacement?
Any suggestions on good places to get them refurb'ed please?
Thanks,
Richard
Post #902853 13th May 2021 1:27pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Give Millers Power EcoMax a go before you go down that road.
Post #902855 13th May 2021 1:37pm
mini Anaconda
Have you changed your fuel filter recently? BORG - Bucks & Oxon 4x4 Response Group
Post #902857 13th May 2021 1:52pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
try new fuel filter and possibly new air filter
Post #902865 13th May 2021 3:14pm
spudfan
Ireland
It could be the vanes in the turbo wearing. Take off the hose going to the turbo and see how much play there is. There will be slight play but you will know if it is excessive. I had a turbo rebuid at 180,000 miles (+/_) owing to excessive wear. Being down on power would be a symptom of this. If you have clean filters etc, I'd suspect the turbo. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #902908 13th May 2021 6:44pm
fearofweapons
Many thanks all for the suggestions.
The filters are new so I'll check out the Turbo and maybe the Millers additive.
regards,
Richard
Post #903015 14th May 2021 12:52pm
Procta
are the pumps set with the timing? it might be worth getting that checked before you start spending money on other items. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #903324 16th May 2021 1:51am
Mo Murphy
Losing power without smoke tends to indicate a restriction in the supply of fuel.
50 Shades of Pennine Grey
Post #903355 16th May 2021 8:49am
