![]() | Home > Technical > 200TDi losing power... |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 301 ![]() ![]() ![]() |
Give Millers Power EcoMax a go before you go down that road.
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 800 ![]() ![]() |
Have you changed your fuel filter recently? BORG - Bucks & Oxon 4x4 Response Group
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
try new fuel filter and possibly new air filter
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
It could be the vanes in the turbo wearing. Take off the hose going to the turbo and see how much play there is. There will be slight play but you will know if it is excessive. I had a turbo rebuid at 180,000 miles (+/_) owing to excessive wear. Being down on power would be a symptom of this. If you have clean filters etc, I'd suspect the turbo. 1982 88" 2.25 diesel
fearofweapons Member Since: 22 Feb 2016 Location: Blighty Posts: 4 ![]() |
Many thanks all for the suggestions.
The filters are new so I'll check out the Turbo and maybe the Millers additive. regards, Richard |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
are the pumps set with the timing? it might be worth getting that checked before you start spending money on other items.
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2277 ![]() ![]() ![]() |
Losing power without smoke tends to indicate a restriction in the supply of fuel.
