![]() | Home > Puma (Tdci) > poor cold starting |
Could be overfueling,there so fickle with all the electronics on these things 2.4 90 XS
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Could be PSJ issue though I hope not.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5080 ![]() ![]() ![]() |
could it be something simple - glow plugs or a fuel problem
mine sits out every night and several days without starting and works first time Mike |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 ![]() ![]() ![]() |
what the PSJ issue
its been every morning since its been cold. it is tapping but i am sure its the fact its not running right emailed the dealer its had a top half engine so far maybe its need a matching bottom ![]() Dan |
Sorry should have read PCJ's
Piston cooling jets lock into zero flow when cold and no oil gets to the lower parts of the bores (or something like that) once warm they unlock and operate correctly. Only affects early 2007 modles and only cure is to replace engine. There is a GTR out and it is posted here somewhere. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Because of the PCJ issue or something else? As your is, I think, the same age as mine I am keen to know. as you know I have been trying to get a new engine out of them for a while now but they won't play. |
Yep because of the early engine rough start problem I presume its the PCJ issue. I simply printed out the GTR that Miserableolgit posted ![]() ![]() ![]() |
Oh my god!!!! I did that and they thew it out!!!! I am ringing the dealers again now!!!! |
boy trry another dealer,they all get paid for the warranty work if they sold you the truck or not,good luck. 2.4 90 XS
I have jsut been on the phone to the manager and he has asked me to fax over the GTR as well as details as to what Andrews 110 was doing and what he said to his dealers to get the engine. He seems pretty helpful. Andrew are you ok with this? I wont mention your name or anything. PM if you have issues. I am desparate here!!! |
You have a pm Well will have when I send it
OK Andrew, thanks |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Hi guys mine is a 7a732686 the 4/07 not noticed any knocking on mine.But a bit worrying what im hearing.Im keen to know am i warranted a new engine because of this fault.
