![]() | Home > Off Topic > garage lighting |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
As I'm also a 101 owner garage headroom is in short supply so I'm considering swapping out the current LED tube fittings for some daylight 1200x300 LED panels. More lumens and only 8mm projection from the ceiling.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3797 ![]() ![]() |
OK getting to the point I may need lights soon.
I'm going to go with twin batten type and LED I hear on here that Daylight light best? the company that sell the lights have these as an option to add to the light fittings (I'm going for doubles in each light) so 6 or 8 double lights.. Which of these bulbs is best for a garage ? or other recommendations for 5ft LED bulbs. ![]() Thanks |
I'd go for 6500K to get the most daylight-like colour rendering. Data from https://en.wikipedia.org/wiki/Color_temperature
Temperature K | Source 1700 K Match flame, low pressure sodium lamps (LPS/SOX) 1850 K Candle flame, sunset/sunrise 2400 K Standard incandescent lamps 2550 K Soft white incandescent lamps 2700 K "Soft white" compact fluorescent and LED lamps 3000 K Warm white compact fluorescent and LED lamps 3200 K Studio lamps, photofloods, etc. 3350 K Studio "CP" light 5000 K Horizon daylight 5000 K Tubular fluorescent lamps or cool white / daylight compact fluorescent lamps (CFL) 5500 – 6000 K Vertical daylight, electronic flash 6200 K Xenon short-arc lamp [2] 6500 K Daylight, overcast 6500 – 9500 K LCD or CRT screen 15,000 – 27,000 K Clear blue poleward sky |
Hello
Thanks, that's a good guide ![]() |
