Home > Off Topic > garage lighting
Stacey007
garage lighting
Hopefully at some point in 2021 I will have my new garage installed Smile
I'm working away sorting the drainage and retaining wall etc, so lots to keep me busy
Looking at lighting inside though as I can get some stuff ready.
So much choice, warm white, cool white, 4000K, Led. 5000k etc etc.
In my old garage I had a couple of LED strip lights no idea what they were, What is best to work on for a garage environment?
I just put a search in amazon, highest rating and these 4ft 6500K ones came up, they are also cheap at £25 each
https://www.amazon.co.uk/LHome-TRI-Proof-D...s9dHJ1ZQ==
Probably need 6 so if these get the Thumbs Up I will order some.
Thanks
Post #878089 12th Jan 2021 9:47pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
For what it’s worth...
In my Workshop I went for 600mm square LED panels.
42w equivalent, cool white.
Great lights for working under. Really pleased with them. Less than £15/panel.
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #878092 12th Jan 2021 10:08pm
Ianh
Do you have a link to the supplier Clemmo as that looks a good price.
Post #878103 13th Jan 2021 1:32am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I fitted a led strip light the same as the Amazon one in our utility , great light for 6 months then it a slight flicker for a month then just stopped working !!! , not got around to changing it Rolling Eyes
Stew
Post #878118 13th Jan 2021 7:12am
Dinnu
The whitest white light possible for a work space.
Just a safety precaution, check that light does not flicker at supply frequency, as it can make motors turning at 3000rpm look stationary (stroboscopic effect) 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #878129 13th Jan 2021 7:58am
Clemmo
I don’t as it was 18 months ago now. I got them off EBay. I’ve just searched 600 led panel and there is quite a choice.
Clemmo
👍 Make today a little better than yesterday but not so good as tomorrow....
Post #878131 13th Jan 2021 8:05am
ARC99
I swapped the standard tubes out for daylight LED tubes, the Food standard ones are plastic so if you hit them the don't send pits of glass flying about. Think they are Crompton make. Don't make old people mad.
Richard
Post #878161 13th Jan 2021 10:00am
Clemmo
5 panels fitted in single garage
Post #878163 13th Jan 2021 10:26am
Clemmo
2 panels in workshop
Post #878164 13th Jan 2021 10:29am
shaggydog
Good to see a mamod on the desk!
These lights look fantastic, I wonder if you could get them to run of a 12V battery as my garage is sadly marooned from the electrical network. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #878183 13th Jan 2021 11:37am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
The LED driver units that come with these panels typically output 22-42Vdc so you'd need need a small inverter to convert your 12Vdc to 240Vac (to use the supplied driver) or a dc-dc converter to jack your 12Vdc up to the expected range. The former would probably be cheaper albeit somewhat less efficient.
This is the driver that came with each of my Luminent panels a few years back - nominal output = 22-35Vdc
Post #878203 13th Jan 2021 12:52pm
Retroanaconda
Six LED battens in mine, they’re LAP ones from Screwfix. Not expensive, give good light and with no flickering. They can be daisy-chained up to eight units.
Post #878205 13th Jan 2021 1:15pm
Clemmo
Gotta love Mamod....been collecting for 30 years.
Way to many now so starting to let a few go... they are fetching silly money too.
This is the boxed one on the desk. It’s completely unused/unfired. Will fetch around £280
Clemmo
Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Post #878214 13th Jan 2021 1:29pm
JOW240725
I would certainly go LED and consider two rows either side of the vehicle rather than a single row above which could cause a lot of shadowing. Depending on head height you could install strip lights vertically on the wall which can give a good lights.
LED lights are so cheap and low energy, I'd buy a few and if not bright enough just add some more. James
Instagram @suffolk_rovers
Post #878226 13th Jan 2021 2:11pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I bought 2 of these to replace 2 standard 5' strips.
https://www.novelenergylighting.com/osram-...79953.html
The difference is like night and day. These are from a good manufacturer, very easily wired in and when I miswired one of the lights the company sent me out another with no questions asked and asked me to locally dispose of the faulty unit. I realised my mistake and they just said keep both.
All in all, great light and good company too.
Post #878370 14th Jan 2021 1:44am
