![]() | Home > General & Technical (L663) > Engine heater |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2690 ![]() ![]() |
There’s no fuel burning heater on my diesel, I don’t think it’s there unless specified.
4B4B Member Since: 30 Apr 2021 Location: Midlands Posts: 83 ![]() ![]() |
Judging by the answers on this thread, there is no definitive answer as to if all diesels have the FBH as standard or not then. I get that the £1k buys you the remote option to use FBH, (and I've spec'd that in my build), but was just curious if the heater was present on all diesels whether the remote option is spec'd or not. Defender 90 HSE 250D 2022MY - Gave up after two failed orders |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
My 2020 D240 doesn’t have the FBH but uses the remote start to start the engine to warm the cabin and all New Defenders have that system unless you live in a market where a separate engine block heater or Webasto type FBH as fitted to L320 RRS and D3 way back when, is offered as standard (IIRC Scandinavia and Canada get both those heaters either as standard or optional, petrol or diesel. Also the block heater is electrically powered) Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Chris Rogers Member Since: 28 Jun 2011 Location: Berkhamsted Posts: 28 ![]() ![]() |
Anyone know if the V8 has one? annoyingly can't see it on the options list.. 2013 Defender 110 USW
2017 Range Rover Sport SVR 2019 Mercedes X Class V6 |
