Home > Td5 > Defender miss fire
Page 2 of 2 <12
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
no egr valve as it was removed over 10 years ago, i have changed the 3 relays next to the ecu, i even disconected the red plug from the ecu and then switched the ignition on and the relays still click every 10 seconds or so, i an begining to suspect theres an fault in the loom somewhere of maybe some wires are shorting together ? very frustrating as its no obvious where it might be lol
Post #884200 9th Feb 2021 5:04pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Non return valve on the fuel line? Possibly draining back between use and causing fuel starvation when first swtiching on?
Cheap to replace might be worth a go
Post #884209 9th Feb 2021 5:22pm
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
Mine was missing, getting worse and worse , it turned out to be the throttle.
Post #885913 16th Feb 2021 4:45pm
mark1200
Quick update, finally had to admit defeat and get the truck into a local garage and there puzzled too but the ecu has been sent off for testing and they have found a fault and its £375 to be repaired, cheaper than £500 for a replacement. i wont hear anything till next week but hopefully this will get sorted lol. i will report back once i know for all those who are watching .
Post #903032 14th May 2021 3:10pm
mark1200
truck all fixed now but my wallet is broken £900 ouch, ecu repaired and the garage replaced the injector seals and diesel filter as well. As i had no access to a nanocom or spare ecu i had to admit defeat and get it to a local garage and even they were puzzled at first lol but at least i have my truck back and all is well
Post #904052 20th May 2021 10:21am
Page 2 of 2 <12
