Home > Td5 > Defender miss fire |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 72 |
no egr valve as it was removed over 10 years ago, i have changed the 3 relays next to the ecu, i even disconected the red plug from the ecu and then switched the ignition on and the relays still click every 10 seconds or so, i an begining to suspect theres an fault in the loom somewhere of maybe some wires are shorting together ? very frustrating as its no obvious where it might be lol
9th Feb 2021 5:04pm |
The Crab Botherer Member Since: 07 May 2020 Location: WIRRAL Posts: 56 |
Mine was missing, getting worse and worse , it turned out to be the throttle.
16th Feb 2021 4:45pm |
Quick update, finally had to admit defeat and get the truck into a local garage and there puzzled too but the ecu has been sent off for testing and they have found a fault and its £375 to be repaired, cheaper than £500 for a replacement. i wont hear anything till next week but hopefully this will get sorted lol. i will report back once i know for all those who are watching .
14th May 2021 3:10pm |
truck all fixed now but my wallet is broken £900 ouch, ecu repaired and the garage replaced the injector seals and diesel filter as well. As i had no access to a nanocom or spare ecu i had to admit defeat and get it to a local garage and even they were puzzled at first lol but at least i have my truck back and all is well
20th May 2021 10:21am |
