![]() | Home > Technical > Heater |
coolant level ok
pauldgray Member Since: 08 Aug 2020 Location: Hindhead Posts: 14 ![]() ![]() ![]() |
Yep
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 831 ![]() ![]() ![]() |
Does the heater valve move when you turn the knob inside (heater valve seams to be a cheep part on these and breaks often) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Yes, it works fine when driving along at 2000rpm but when stopped on idle the heat stops
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17626 ![]() ![]() ![]() |
This is fairly normal on a TDCi, and provided that the coolant level is well up there is not much you can do about it. The heater is extremely sensitive to coolant level, but will also vary enormously according to what the engine is doing.
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 834 ![]() ![]() ![]() |
Glad I have a 300tdi, it is always reliably luke warm
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
Pretty normal unfortunately. Mine a either cold or hotter than the gates of hell. No really middle ground!!
