Home > Technical > Heater
pauldgray
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
Heater
Can anyone help please, I have a 2009 2.4tdci and the heater when then idle is blowing cold, what do you suggest to improve this ? It is perfect when the revs are 2000 +
Post #873417 17th Dec 2020 11:41am
dorsetsmith
coolant level ok Question
Post #873419 17th Dec 2020 11:54am
pauldgray
Yep
Post #873423 17th Dec 2020 12:28pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Does the heater valve move when you turn the knob inside (heater valve seams to be a cheep part on these and breaks often) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #873425 17th Dec 2020 12:35pm
pauldgray
Yes, it works fine when driving along at 2000rpm but when stopped on idle the heat stops
Post #873426 17th Dec 2020 12:37pm
This is fairly normal on a TDCi, and provided that the coolant level is well up there is not much you can do about it. The heater is extremely sensitive to coolant level, but will also vary enormously according to what the engine is doing.
Post #873439 17th Dec 2020 2:18pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Glad I have a 300tdi, it is always reliably luke warm Rolling with laughter
Post #873533 18th Dec 2020 12:34am
Co1
Pretty normal unfortunately. Mine a either cold or hotter than the gates of hell. No really middle ground!!
Post #873538 18th Dec 2020 7:15am
