![]() | Home > Technical > Help ID some parts please - Puma |
LR059968
Seal-swivel pin housing, 9MM pic 4/5 Front Axel seals seem to be leaking , also seal need when replacing Seal-swivel gasket swvel pin bearing housing FTC3646 x 2 and seal front drive shaft FTC 3276 x2 JQD500080 Heating Control Valve pic 3/6 LR068982 Clutch Slave Cylinder Control Valve pic 1/2 https://www.lrworkshop.com/ link to on line parts manual Last edited by dorsetsmith on 8th Nov 2020 1:35pm. Edited 1 time in total |
bodelafela Member Since: 25 Feb 2016 Location: Brisbane Posts: 18 ![]() ![]() |
Thanks mate
that was super helpful |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2176 ![]() ![]() |
Re the heater control valve. It’s a common fault but changing the valve out is simple. See https://www.defender2.net/forum/topic54969.html for a good discussion on putting a completely different type of valve on (complex) or changing for the same type but sourced via ALFA ROMEO ,CITROEN, FIAT, LANCIA or PEUGEOT part numbers at a much cheaper price. Ie I purchased one for £27 .
Alternate part numbers. ALFA ROMEO 77363342 CITROEN 6448P6 FIAT 77363342 LANCIA 77363342 PEUGEOT 6448P6 |
would anyone also know
what parts I would need to swap out the front and rear brakes - Im told I need the discs and the pads ( front and rear ) was wondering if I needed to get any other seals etc for this change over to happen ![]() Click image to enlarge |
Here is a good source for part numbers and diagrams https://www.lrworkshop.com/diagrams
having seen your pic you have Vented Discs front brake you need to remove front and rear hubs to replace the disc so 4 new hub inner seals FTC4785 and 4 new locking nuts RFD10000 solid discs pads for the rear |
