Home > Technical > Help ID some parts please - Puma
bodelafela
Australia
Ive just completed a rebuild of a output shaft with a Ashcroft unit
Runs great and feels like I have a few extra Hp off the lights Smile
Noticed a few issues while having my head under
1) There is a water drip from a unit that seems to be artached to the heater cable - its dripping coolant
2) There is a oil leak ( clutch oil ..not sure if thats a thing , but def some sort of oil ) from this plastic sleeve when ever the clutch is pressed down
3)Front Axel seals seem to be leaking ? thats what I am calling them , but they may be called something else
Could someone please help with this info
Post #866016 8th Nov 2020 10:10am
dorsetsmith
LR059968
Seal-swivel pin housing, 9MM pic 4/5 Front Axel seals seem to be leaking , also seal need when replacing Seal-swivel gasket swvel pin bearing housing FTC3646 x 2 and seal front drive shaft FTC 3276 x2
JQD500080
Heating Control Valve pic 3/6
LR068982
Clutch Slave Cylinder Control Valve pic 1/2
https://www.lrworkshop.com/ link to on line parts manual
Post #866021 8th Nov 2020 10:26am
bodelafela
Australia
Thanks mate
that was super helpful
Post #866027 8th Nov 2020 11:19am
Ianh
Re the heater control valve. It’s a common fault but changing the valve out is simple. See https://www.defender2.net/forum/topic54969.html for a good discussion on putting a completely different type of valve on (complex) or changing for the same type but sourced via ALFA ROMEO ,CITROEN, FIAT, LANCIA or PEUGEOT part numbers at a much cheaper price. Ie I purchased one for £27 .
Alternate part numbers.
ALFA ROMEO 77363342
CITROEN 6448P6
FIAT 77363342
LANCIA 77363342
PEUGEOT 6448P6
Post #866035 8th Nov 2020 12:06pm
bodelafela
Australia
would anyone also know
what parts I would need to swap out the front and rear brakes
- Im told I need the discs and the pads ( front and rear )
was wondering if I needed to get any other seals etc for this change over to happen
Post #866037 8th Nov 2020 12:09pm
Ianh
Here is a good source for part numbers and diagrams https://www.lrworkshop.com/diagrams
Post #866050 8th Nov 2020 12:59pm
dorsetsmith
having seen your pic you have Vented Discs front brake you need to remove front and rear hubs to replace the disc so 4 new hub inner seals FTC4785 and 4 new locking nuts RFD10000
solid discs pads for the rear
Post #866065 8th Nov 2020 2:29pm
