Home > Maintenance & Modifications > Front Brake Discs and pads |
T3DDY14 Member Since: 23 Jul 2020 Location: Kent Posts: 32 |
Was planning on replacing the front brake discs and pads, and was wondering if these are worth the EBC ones or to go with britpart ones
EBC Brake discs: https://www.lrparts.net/da4151-ebc-front-s...-1986.html EBC Brake pads: https://www.lrparts.net/da4560-ebc-yellow-...wards.html Britpart discs: https://www.lrparts.net/da4602-britpart-fr...assic.html pads: https://www.lrparts.net/sfp000260-brake-pa...wards.html Defender 110 300tdi hard top |
16th Sep 2020 7:05pm |
Current ones seem to be vented
Click image to enlarge This is one of the brake discs, the reason it looks so bad is due to a recent accident, which is on another post Defender 110 300tdi hard top |
16th Sep 2020 7:45pm |
I have seen that post.
So these are vented discs. The britparts version are too thin for the calipers you have. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Sep 2020 7:53pm |
So the EBC one would be right for the front axles, also another question what is the difference between yellow and green brake pads? as the yellow ones are more expensive than the green ones. Defender 110 300tdi hard top
16th Sep 2020 8:00pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Yellow is meant for heavier vehicles, green is traditionally meant for the back axle in heavy cars and the front on lighter cars (Elise etc), anything over 1200kg can wreck greens on the front, I managed to make a set of green stuff explode in my MINI Cooper front calipers.
16th Sep 2020 8:07pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
i like the ebc pads, i use them on my mini and defender.
black stuff is for normal road going cars green stuff is for fast road yellow is for track days red is for racing. I used the green stuff pads in the classic mini but they take a little bit of time to warm up and become effective. so now i use blackstuff in both cars and they are great. 1953 80" 1987 mini city e 2011 90" |
16th Sep 2020 8:30pm |
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 |
What about genuine?
17th Sep 2020 6:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17519 |
I have used Delphi discs and genuine pads for years, and have no complaints at all with them. Genuine pads are the only ones I have found which don't squeal or rattle so I am happy to pay the "genuine premium". Discs, and when necessary calipers, I get from delphi who (I believe) supplied them to LR originally and are great value.
17th Sep 2020 6:58pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
I can recommend LOF brakes, just done all 4 corners of mine.
Good quality and good price for the full kit Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
17th Sep 2020 9:56pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Standard Delphi discs and pads all around for me. Used Ferodo in the past but they delaminated. I don't have any issues with squeal but i I use the stainless rear anti squeal shims and double springs on the rear pads to stop them rattling.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th Sep 2020 2:28pm |
I don't know what discs I have. They could be original with 108000 M ?
For pads I use the cheapest I can get as when off-roading in soft wet sand they are gone in a day and that happens with cheap one and expensive ones. On the road I think the cheap ones wear quicker but I don't have problems with squealing. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
18th Sep 2020 4:50pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
standard EBC black pads on mine no issues, have used black and green on all my normal cars since I can remember and always been happy with them, generally well priced and delivered directly very quickly DEFENDER 90 TDCI XS,
18th Sep 2020 5:49pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
I have grooved/drilled disc's front and back and only used green stuff on the front and different makes on the back, but most would squeal at some point the pads on the rear, but just recently i have put these on all four corners and so far so good and work straight away, they are for SUV's and 4x4's
Click image to enlarge Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
18th Sep 2020 9:12pm |
Steve, I'd be interested to know about your double springs. My rear pads do rattle a bit (you can only hear it with the window down) and I'd like to solve it if I can. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
18th Sep 2020 9:38pm |
