Home > Maintenance & Modifications > Front Brake Discs and pads
T3DDY14
United Kingdom 1998 Defender 110 300 Tdi HT Alaska White
Was planning on replacing the front brake discs and pads, and was wondering if these are worth the EBC ones or to go with britpart ones
EBC Brake discs:
https://www.lrparts.net/da4151-ebc-front-s...-1986.html
EBC Brake pads:
https://www.lrparts.net/da4560-ebc-yellow-...wards.html
Britpart discs:
https://www.lrparts.net/da4602-britpart-fr...assic.html
pads:
https://www.lrparts.net/sfp000260-brake-pa...wards.html Defender 110 300tdi hard top
Post #856340 16th Sep 2020 8:05pm
roel
What do you have on the moment for discs? As how I see it these are not the same. The Britparts are solid discs with some grooves and holes and the EBC are vented discs so two separate plates. For these you normally need different calipers.
If you drive in mountains regularly I would go with vented disc from a decent supplier. Roel
2003 90 Td5 (2009-now)
Post #856350 16th Sep 2020 8:27pm
T3DDY14
Current ones seem to be vented
This is one of the brake discs, the reason it looks so bad is due to a recent accident, which is on another post Defender 110 300tdi hard top
Post #856361 16th Sep 2020 8:45pm
roel
I have seen that post.
So these are vented discs. The britparts version are too thin for the calipers you have. Roel
Post #856366 16th Sep 2020 8:53pm
T3DDY14
So the EBC one would be right for the front axles, also another question what is the difference between yellow and green brake pads? as the yellow ones are more expensive than the green ones. Defender 110 300tdi hard top
Post #856369 16th Sep 2020 9:00pm
kenzle8a
Yellow is meant for heavier vehicles, green is traditionally meant for the back axle in heavy cars and the front on lighter cars (Elise etc), anything over 1200kg can wreck greens on the front, I managed to make a set of green stuff explode in my MINI Cooper front calipers.
Post #856373 16th Sep 2020 9:07pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i like the ebc pads, i use them on my mini and defender.
black stuff is for normal road going cars
green stuff is for fast road
yellow is for track days
red is for racing.
I used the green stuff pads in the classic mini but they take a little bit of time to warm up and become effective.
so now i use blackstuff in both cars and they are great. 1953 80"
1987 mini city e
2011 90"
Post #856379 16th Sep 2020 9:30pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
What about genuine?
Post #856554 17th Sep 2020 7:44pm
I have used Delphi discs and genuine pads for years, and have no complaints at all with them. Genuine pads are the only ones I have found which don't squeal or rattle so I am happy to pay the "genuine premium". Discs, and when necessary calipers, I get from delphi who (I believe) supplied them to LR originally and are great value.
Post #856560 17th Sep 2020 7:58pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I can recommend LOF brakes, just done all 4 corners of mine.
Good quality and good price for the full kit Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #856600 17th Sep 2020 10:56pm
rallysteve
Standard Delphi discs and pads all around for me. Used Ferodo in the past but they delaminated. I don't have any issues with squeal but i I use the stainless rear anti squeal shims and double springs on the rear pads to stop them rattling.
Post #856669 18th Sep 2020 3:28pm
roel
I don't know what discs I have. They could be original with 108000 M ?
For pads I use the cheapest I can get as when off-roading in soft wet sand they are gone in a day and that happens with cheap one and expensive ones.
On the road I think the cheap ones wear quicker but I don't have problems with squealing. Roel
Post #856685 18th Sep 2020 5:50pm
LR90XS2011
standard EBC black pads on mine no issues, have used black and green on all my normal cars since I can remember and always been happy with them, generally well priced and delivered directly very quickly DEFENDER 90 TDCI XS,
Post #856694 18th Sep 2020 6:49pm
L110CDL
I have grooved/drilled disc's front and back and only used green stuff on the front and different makes on the back, but most would squeal at some point the pads on the rear, but just recently i have put these on all four corners and so far so good and work straight away, they are for SUV's and 4x4's
Very Happy Clayton.
Keeper.
Post #856751 18th Sep 2020 10:12pm
ozzie1989
Steve
Steve, I'd be interested to know about your double springs. My rear pads do rattle a bit (you can only hear it with the window down) and I'd like to solve it if I can. Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Post #856757 18th Sep 2020 10:38pm
