Home > Technical > Failed MOT (Belgium)
Christophe
Belgium 2004 Defender 110 Td5 DCPU Java Black
Recently went for an MOT with my defender 90 2.4tdci (Belgium) and it failed. Why?
Because you're able to remove the key from the ignition while the engine is running and the ignition is on. I always thought this was a "feature" of the Defender but does this mean I have a faulty ignition switch/barrel?
Post #850647 18th Aug 2020 8:00am
rallysteve
yes, you should not be able to do this!
Would suggest a new ignition barrel/steering lock unit.
Post #850650 18th Aug 2020 8:13am
discomog
Sounds like either a worn key or a worn barrel (or both). As Rallysteve says, looks like you need to replace. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #850672 18th Aug 2020 11:19am
Christophe
Will go about changing the ignition barrel next weekend. Thumbs Up Cheers! 04' 110 TD5 Double Cab
10' 90 2.4tdci Station Wagon
Post #850969 19th Aug 2020 4:38pm
Dinnu
Does the steering lock in such a situation?.. I hope not. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #851011 19th Aug 2020 7:13pm
mini Anaconda
My 90 had this "limited edition" feature when I bought it. Confused BORG - Bucks & Oxon 4x4 Response Group
Post #851061 20th Aug 2020 6:10am
Christophe
No it doesn't! Don't think that's possible, the key would have to go back to the off position by itself. 04' 110 TD5 Double Cab
Post #851099 20th Aug 2020 11:24am
Christophe
Same here... 04' 110 TD5 Double Cab
Post #851100 20th Aug 2020 11:24am
Martyn668
Some low lives tried to steal my diesel Series III many years ago, and bust the steering lock in the process. They didn't manage to steal it, but it had this "feature" afterwards. I no longer had to pull the manual solenoid to kill the engine, to then be able to remove the key. If I turned the key to position 0, I could remove it with the engine still running. The battery warning light came did come on though. I was told the alternator was spinning and trying to charge, but wasn't able to do so; I could potentially damage the alternator.
Post #852687 28th Aug 2020 5:10pm
