![]() | Home > Technical > Failed MOT (Belgium) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
yes, you should not be able to do this!
Would suggest a new ignition barrel/steering lock unit. Steve 02' 110 TD5 Double Cab Rebuild Thread |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Sounds like either a worn key or a worn barrel (or both). As Rallysteve says, looks like you need to replace. Defender 90XS SW
Christophe Member Since: 18 Aug 2020 Location: Sint-Truiden Posts: 12 ![]() ![]() ![]() |
Will go about changing the ignition barrel next weekend.
![]() 10' 90 2.4tdci Station Wagon |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3494 ![]() ![]() ![]() |
Does the steering lock in such a situation?.. I hope not. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 806 ![]() ![]() |
My 90 had this "limited edition" feature when I bought it.
No it doesn't! Don't think that's possible, the key would have to go back to the off position by itself. 04' 110 TD5 Double Cab 10' 90 2.4tdci Station Wagon |
Same here... 04' 110 TD5 Double Cab 10' 90 2.4tdci Station Wagon |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 ![]() ![]() |
Some low lives tried to steal my diesel Series III many years ago, and bust the steering lock in the process. They didn't manage to steal it, but it had this "feature" afterwards. I no longer had to pull the manual solenoid to kill the engine, to then be able to remove the key. If I turned the key to position 0, I could remove it with the engine still running. The battery warning light came did come on though. I was told the alternator was spinning and trying to charge, but wasn't able to do so; I could potentially damage the alternator.
