Home > Maintenance & Modifications > Strange Intake Noise
Page 2 of 4 <1234>
PCM
Darren
Any update on the above? Did they find it?
Post #848304 6th Aug 2020 2:24am
Ah, not yet. The tomorrow I mentioned is today Laughing Darren
Post #848310 6th Aug 2020 6:49am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sounds very similar to my 2.2, never thought it was a problem.
Post #848322 6th Aug 2020 7:36am
Siwynne
Same noise in mine been there for approximately 60 thousand Miles in my ownership.
Post #848356 6th Aug 2020 11:24am
Thanks chaps. There's clearly something amiss though, because of the occasional power drops that accompany the noise. Regardless though, it's in the garage now so I'll hopefully find out more later. Darren
Post #848361 6th Aug 2020 11:55am
Ok, I'm an idiot. Or oversensitive, or possibly both. Despite plugging it in, giving it a good look over and test drive, they couldn't find anything wrong. The noise, apparently, is just the actuator for the turbo vanes working and whilst they didn't actually say 'they all do that, sir,' it was definitely implied Embarassed
On the plus side, kudos to Challenger 4x4 for not charging me anything for this little escapade.
In the drive home, it behaved impeccably Rolling Eyes Darren
Post #848398 6th Aug 2020 5:20pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Only just seen this thread, and would have been reluctant to comment anyway given your username and normal knowledge levels
but.. as a couple of others said, sounds just like my 2.2 that has done it from new (much more noticeable with the window down) and as you say you can almost do it on purpose by throttle/gear changes. It has also been mentioned a few times, generally by new owners.
Post #848417 6th Aug 2020 7:08pm
That must have completely passed me by, unfortunately. The only other related stuff I'd come across was in connection with the EGR valve, but that was replaced on mine last year.
Hey ho, you live and learn. Darren
Post #848418 6th Aug 2020 7:17pm
apt100
At least it's extra reassurance for the rest of us. So far no one has said mine made that noise just before <something> happened Thumbs Up
Post #848421 6th Aug 2020 7:25pm
Very true Laughing Darren
Post #848428 6th Aug 2020 7:42pm
So, despite all that I said above, this issue has still been niggling me. The occasional power hiccup and the odd noises convinced me that there was still something wrong. As a bit of a gamble therefore, I've replaced the turbo actuator and lo and behold, normal service has been resumed. Took it for a long test drive this morning to get it good and hot, and couldn't replicate the symptoms at all.
I can only assume that the actuator was sticking at one end of its' travel and then snapping back, hence the sound like a valve closing. I'll try and strip down the old one to see if there's anything obvious.
I was concerned that it might be a fault with the turbo itself but with the actuator removed, the linkage was completely free to move with no sign of anything sticking. Anyway, fingers crossed... Darren
Post #853109 30th Aug 2020 12:29pm
Landymatt
Interesting narrative, sounds like you ‘knew’ in your gut something wasn’t quite right and it’s likely turning out to be true!
Post #853117 30th Aug 2020 1:17pm
Yeah, kind of.
I've now stripped apart the old unit but disappointingly, there's no smoking gun. The inside is as clean as a whistle and when I applied 12v to the motor, it ran smoothly in both directions, albeit noisily one way. I'll just have to see how it goes.
 Darren
Post #853136 30th Aug 2020 4:11pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Do you still have the strange sound or the replacement actuator sort it? WARNING.
This post may contain sarcasm.
Post #853148 30th Aug 2020 5:58pm
Some time ago my actuator stuck on full boost (the well known chafed harness fault) and the induction noise was extremely spectacular!
Post #853160 30th Aug 2020 6:48pm
Page 2 of 4 <1234>
