Home > Maintenance & Modifications > Strange Intake Noise |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Darren
Any update on the above? Did they find it? |
6th Aug 2020 2:24am |
Ah, not yet. The tomorrow I mentioned is today Darren
6th Aug 2020 6:49am |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
Sounds very similar to my 2.2, never thought it was a problem.
6th Aug 2020 7:36am |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
Same noise in mine been there for approximately 60 thousand Miles in my ownership.
6th Aug 2020 11:24am |
Thanks chaps. There's clearly something amiss though, because of the occasional power drops that accompany the noise. Regardless though, it's in the garage now so I'll hopefully find out more later. Darren
6th Aug 2020 11:55am |
Ok, I'm an idiot. Or oversensitive, or possibly both. Despite plugging it in, giving it a good look over and test drive, they couldn't find anything wrong. The noise, apparently, is just the actuator for the turbo vanes working and whilst they didn't actually say 'they all do that, sir,' it was definitely implied
On the plus side, kudos to Challenger 4x4 for not charging me anything for this little escapade. In the drive home, it behaved impeccably Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Aug 2020 5:20pm |
That must have completely passed me by, unfortunately. The only other related stuff I'd come across was in connection with the EGR valve, but that was replaced on mine last year.
Hey ho, you live and learn. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Aug 2020 7:17pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
At least it's extra reassurance for the rest of us. So far no one has said mine made that noise just before <something> happened
6th Aug 2020 7:25pm |
Very true Darren
6th Aug 2020 7:42pm |
So, despite all that I said above, this issue has still been niggling me. The occasional power hiccup and the odd noises convinced me that there was still something wrong. As a bit of a gamble therefore, I've replaced the turbo actuator and lo and behold, normal service has been resumed. Took it for a long test drive this morning to get it good and hot, and couldn't replicate the symptoms at all.
I can only assume that the actuator was sticking at one end of its' travel and then snapping back, hence the sound like a valve closing. I'll try and strip down the old one to see if there's anything obvious. I was concerned that it might be a fault with the turbo itself but with the actuator removed, the linkage was completely free to move with no sign of anything sticking. Anyway, fingers crossed... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
30th Aug 2020 12:29pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
Interesting narrative, sounds like you ‘knew’ in your gut something wasn’t quite right and it’s likely turning out to be true!
30th Aug 2020 1:17pm |
Yeah, kind of.
I've now stripped apart the old unit but disappointingly, there's no smoking gun. The inside is as clean as a whistle and when I applied 12v to the motor, it ran smoothly in both directions, albeit noisily one way. I'll just have to see how it goes. Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
30th Aug 2020 4:11pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3291 |
Do you still have the strange sound or the replacement actuator sort it? WARNING.
This post may contain sarcasm. |
30th Aug 2020 5:58pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Some time ago my actuator stuck on full boost (the well known chafed harness fault) and the induction noise was extremely spectacular!
30th Aug 2020 6:48pm |
