Home > Maintenance & Modifications > Strange Intake Noise
Page 1 of 4 1234>
Hello folks,
Can anybody help with a strange intake noise that my 110 has developed? It sounds, for all the world, like somebody cupping their hand over the end of a vacuum cleaner hose and typically happens at the point of changing up from first to second and second to third. Also occasionally when feathering a light throttle. It generally doesn't affect performance, although occasionally it's accompanied by a 'hiccup'.
It's been doing it for ages, on and off, and I originally thought it was the EGR valve, but a new replacement didn't make any difference. Since then, it's had a new, larger intercooler, new silicon hoses and the pipe from wing to airbox replaced by a much larger diameter one as part of the snorkel install.
Last week, I discovered that one of the airbox lid clips had gone AWOL and thought I'd found the culprit, but again fitting a replacement has made no difference, which has led me to ask for help here.
The only thing of significance left between open air and the inlet manifold is the turbo. Could it be something like a sticking wastegate? If so, any pointers on how to approach?
Thanks, all. Darren
Post #844681 19th Jul 2020 8:37am
ickle
Viscous fan?
Keith
Post #844684 19th Jul 2020 8:39am
No, I'm pretty sure it's somewhere in the air intake system. Since fitting the snorkel, it's become very easy to hear it above everything else. Darren
Post #844691 19th Jul 2020 9:09am
Anybody got any more thoughts, folks? Darren
Post #844792 19th Jul 2020 9:34pm
PCM
Could your new hoses be collapsing?
Post #844801 20th Jul 2020 1:08am
Dunno Confused It's possible I suppose, but the noise was there before and after the change, so seems less likely. Darren
Post #844807 20th Jul 2020 7:18am
PCM
It'd have to be on the intake side sucking instead of an intercooler pressure.
Do you have anything that could be crumpling but springing back when the revs drop?
Post #844810 20th Jul 2020 7:46am
Nothing obvious. The pipe from RAI to airbox is now a length of 90mm spiral wound flexi pipe but it's good quality stuff that came as part of the Nakatanenga kit. Plus, as with the other hoses, the problem was there both before and after its' installation. Darren
Post #844819 20th Jul 2020 8:24am
markb110
Just a thought but worth asking
Have you have the vehicle serviced just before the noise started. Worth checking the Air intake pipes in case they were disconnected and then had a rag stuffed into them to keep crud out of them, then accidentally left in place.
Happened to me once on my previous 300Tdi.
Post #844821 20th Jul 2020 8:49am
Grenadier
Christ LRA, if you don’t know, how do you expect any of us to have the foggiest? Blackwolf might be your saviour, beyond that you have to look to the heavens for some devine intervention Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #844829 20th Jul 2020 9:35am
Apart from noting that it won't be a sticking wastegate because you don't have one, you have a variable vane turbo, I don't have much to add, I'm afraid. It is an odd noise, that's for sure! You say that sometimes there is a hiccup at the same time? Do you have any stored fault codes?
I'll ponder about this for a while, and see if I can come up with any ideas (being mindful that I am less familiar with the 2.2 than the 2.4).
Post #844832 20th Jul 2020 9:43am
Hmm, thanks chaps. I can't tie it back to a particular service visit, unfortunately. In fact, that last two visits including replacing the EGR and intercooler/pipework respectively, with no apparent change.
Noted about the wastegate. If I'd thought about it more then I'd have realised that but can't get away from the thought that it sounds a bit like a dump valve Confused I haven't checked for fault codes but I'm not getting any warning lights. I'll plug in my IID and see if it says anything useful.
Unfortunately Grenadier, the only special power that my anorak provides is a degree of obsessing about details Laughing Darren
Post #844842 20th Jul 2020 11:07am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Stock airbox? are the two plastic "hooks" under the wing engaged? I have had a mechanic set the airbox lid on and snap closed the metal clips leaving the other side of the airbox not fastened proplerly. Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #844848 20th Jul 2020 11:45am
It's been on and off a few times but it's worth a check Thumbs Up Darren
Post #844861 20th Jul 2020 1:11pm
Well, having failed to find anything obvious, I've dispatched it to my local LR indie for them to take a look tomorrow. Hopefully, they'll have better luck than me Rolling Eyes Darren
Post #848290 5th Aug 2020 8:40pm
Page 1 of 4 1234>
