Home > Technical > Switch backlight replacement leds |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Not replaced them but modified a switch. Soldering in a new LED should be no problem.
Should be similar to these https://www.reichelt.com/de/en/green-3-mm-...54094.html I guess getting the right type of green and the same brightness would be trial and error. Did you check them by supplying 12V to each LED separately? It's strange that two of them should fail at the same time. |
1st Jul 2020 7:45pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 634 |
One failed a while ago, now another one has gone. Good power and earth from switches.
I was going to get a couple of old freelander ones and rob the leds from them. |
1st Jul 2020 8:37pm |
