Home > Technical > Switch backlight replacement leds
Oldowner
The rear screen wash and rear screen wipe push button switches on my Puma have lost their backlighting. Has anyone tried replacing the small leds which are soldered on to the switches?
Post #840376 29th Jun 2020 6:35am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Not replaced them but modified a switch. Soldering in a new LED should be no problem.
Should be similar to these
https://www.reichelt.com/de/en/green-3-mm-...54094.html
I guess getting the right type of green and the same brightness would be trial and error.
Did you check them by supplying 12V to each LED separately?
It's strange that two of them should fail at the same time.
Post #841137 1st Jul 2020 7:45pm
Oldowner
One failed a while ago, now another one has gone. Good power and earth from switches.
I was going to get a couple of old freelander ones and rob the leds from them.
Post #841169 1st Jul 2020 8:37pm
