![]() | Home > Technical > Switch backlight replacement leds |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
Not replaced them but modified a switch. Soldering in a new LED should be no problem.
Should be similar to these https://www.reichelt.com/de/en/green-3-mm-...54094.html I guess getting the right type of green and the same brightness would be trial and error. ![]() Did you check them by supplying 12V to each LED separately? It's strange that two of them should fail at the same time. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 650 ![]() ![]() ![]() |
One failed a while ago, now another one has gone. Good power and earth from switches.
I was going to get a couple of old freelander ones and rob the leds from them. |
