Home > Maintenance & Modifications > Acoustic Mats vs Trad Sound Proofing with Carpet ?
StephenTD5
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
I'm about to start my interior overhaul
What are people thoughts and experiences when it comes to soundproofing and re-carpeting?
This seems like a fairly low effort solution so it's tempting...
https://www.firstfour.co.uk/acoustic-mat-s...black.html Defender 90 Td5
BMW M4 Competition
Jaguar XJ6 Sovereign
Post #829039 3rd May 2020 3:59pm
jst
That's the wright matting system. I have used it in 4 vehicles. Really like the simplicity and closed cell. Its clean, functional and hard wearing. It reduces noise but prob not as much as butyl sheets and foam/carpet. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829060 3rd May 2020 5:23pm
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
I can’t comment on the effectiveness of the product you’ve suggested above but I’ve recently added Dynamat Extreme and the Dynaliner to the rear of my 110 and it’s made a HUGE difference.
My plan will be to eventually do the front part of the cabin but waiting to see some carpet options to put over the rear before I take up the standard Factory rubber floor covering.
Post #829068 3rd May 2020 6:02pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I have the Wright Offroad Mat system in the front of my 110- Made a big difference when we fitted it, its also hugely practical and easy to clean.
Its what they should have left the factory with.
Edit; if you want one of the Wright offroad systems- let me know and Ill pass on Drews Contact details so you can buy direc from him.
After that- the next biggest jump in terms of reducing sound was to cover the roof in closed cell foam.
We are just working on Version 2 of trying to make the 110 quieter, Im adding bits of sound deadening material strategically to places- we have gone for about 80% coverage under the rear seats, rear floor and wheelarches with a dynamat equivalent.
We have then added an 8mm layer of closed cell foam, then carpeted over some areas with automotive carpet and added a rubber mat over the floors where feet go.
I have just started adding some bits inside the doors- the internal framing has had some deadening added, and some additional foam which seems to make a big difference.
Regards
Chris
Post #829070 3rd May 2020 6:29pm
StephenTD5
Thanks All, I think I will start with some Dynamat sheets and then maybe add the Wrights matt set on top in the front cab Defender 90 Td5
BMW M4 Competition
Post #829147 4th May 2020 7:23am
K.M
Good decision... I found this place to be cheaper than anywhere else I looked
https://www.justkampers.com/search/result/?q=dynamat+extreme
I'm not sure if I need to say or not but I'm not affiliated in any way to the company blah blah blah
Post #829149 4th May 2020 7:47am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Dynamat extreme, it’s expensive, but the best. I also have a 3mm closed cell foam barrier over the top on the floor, sides, and roof. Cuts down noise, basically any flat interior panel, stick it on. Few tips, makes sure you get a roller and the surface you are sticking too is clean, or it will lift, especially on the roof sections.
Post #829154 4th May 2020 8:11am
jst
Wow, that dynamite stuff is £££££.
Do they sell them in vehicle packs? Or does anyone know how many of what size to do a 110 use? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829299 4th May 2020 8:45pm
2010Blackdefender90
Several places do pre cut areas, seat box, rear load deck, bonnet etc. If you want to do it in stages, suggest start from the rear and work forward, this way you can budget, but don’t buy the cheap stuff, it won’t stick properly, especially under extremes, heat and cold and will lift up, especially on the roof.
Also, use a closed cell foam barrier, this absorbs sound, use it on the roof and gearbox tunnel, 6mm, inside the door cards 3mm.
Post #829357 5th May 2020 10:30am
Silentcoat is a generally cheaper alternative to Dynamat and is essentially the same product. Have a look for the Sound Deadening Shop on eBay for some decent bundle deals.
I've used this product combined with generic 6mm foam on two vehicles now and been very pleased with the results. Darren
Post #829363 5th May 2020 10:51am
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Thumbs Up What Darren said - I used silentcoat through my 90 - probably spent about £180, the closed cell foam is cheap as chips.
Post #829383 5th May 2020 3:15pm
2010Blackdefender90
Post #829432 5th May 2020 8:54pm
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
how does dynamat or any sound deadening react with any leaks? (Thinking more footwell if they get damp and trap that moisture making things corrosion prone?)
Post #830226 10th May 2020 10:12am
2010Blackdefender90
Fix the leaks first, it sticks, water ingress is not good, and it will lift up.
Post #830233 10th May 2020 10:22am
90GTR
Thanks.
Car currently has carpet rear and rubber matting up front - and really is not overly loud. However, I did notice engine noise almost from the bulkhead. Have you fitted any under bonnet dynamat and if so, huge difference?
Post #830506 11th May 2020 5:18pm
