Home > Maintenance & Modifications > Acoustic Mats vs Trad Sound Proofing with Carpet ? |
StephenTD5 Member Since: 04 Sep 2019 Location: Berkshire Posts: 39 |
I'm about to start my interior overhaul
What are people thoughts and experiences when it comes to soundproofing and re-carpeting? This seems like a fairly low effort solution so it's tempting... https://www.firstfour.co.uk/acoustic-mat-s...black.html Defender 90 Td5 BMW M4 Competition Jaguar XJ6 Sovereign |
3rd May 2020 3:59pm |
K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300 |
I can’t comment on the effectiveness of the product you’ve suggested above but I’ve recently added Dynamat Extreme and the Dynaliner to the rear of my 110 and it’s made a HUGE difference.
My plan will be to eventually do the front part of the cabin but waiting to see some carpet options to put over the rear before I take up the standard Factory rubber floor covering. Click image to enlarge Click image to enlarge |
3rd May 2020 6:02pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 791 |
I have the Wright Offroad Mat system in the front of my 110- Made a big difference when we fitted it, its also hugely practical and easy to clean.
Its what they should have left the factory with. Edit; if you want one of the Wright offroad systems- let me know and Ill pass on Drews Contact details so you can buy direc from him. After that- the next biggest jump in terms of reducing sound was to cover the roof in closed cell foam. We are just working on Version 2 of trying to make the 110 quieter, Im adding bits of sound deadening material strategically to places- we have gone for about 80% coverage under the rear seats, rear floor and wheelarches with a dynamat equivalent. We have then added an 8mm layer of closed cell foam, then carpeted over some areas with automotive carpet and added a rubber mat over the floors where feet go. I have just started adding some bits inside the doors- the internal framing has had some deadening added, and some additional foam which seems to make a big difference. Regards Chris |
3rd May 2020 6:29pm |
Thanks All, I think I will start with some Dynamat sheets and then maybe add the Wrights matt set on top in the front cab Defender 90 Td5
4th May 2020 7:23am |
Good decision... I found this place to be cheaper than anywhere else I looked
https://www.justkampers.com/search/result/?q=dynamat+extreme I'm not sure if I need to say or not but I'm not affiliated in any way to the company blah blah blah |
4th May 2020 7:47am |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Dynamat extreme, it’s expensive, but the best. I also have a 3mm closed cell foam barrier over the top on the floor, sides, and roof. Cuts down noise, basically any flat interior panel, stick it on. Few tips, makes sure you get a roller and the surface you are sticking too is clean, or it will lift, especially on the roof sections.
4th May 2020 8:11am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8096 |
Wow, that dynamite stuff is £££££.
Do they sell them in vehicle packs? Or does anyone know how many of what size to do a 110 use? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th May 2020 8:45pm |
Several places do pre cut areas, seat box, rear load deck, bonnet etc. If you want to do it in stages, suggest start from the rear and work forward, this way you can budget, but don’t buy the cheap stuff, it won’t stick properly, especially under extremes, heat and cold and will lift up, especially on the roof.
Also, use a closed cell foam barrier, this absorbs sound, use it on the roof and gearbox tunnel, 6mm, inside the door cards 3mm. |
5th May 2020 10:30am |
Silentcoat is a generally cheaper alternative to Dynamat and is essentially the same product. Have a look for the Sound Deadening Shop on eBay for some decent bundle deals.
I've used this product combined with generic 6mm foam on two vehicles now and been very pleased with the results. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th May 2020 10:51am |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 |
What Darren said - I used silentcoat through my 90 - probably spent about £180, the closed cell foam is cheap as chips.
5th May 2020 3:15pm |
5th May 2020 8:54pm |
90GTR Member Since: 05 May 2020 Location: London Posts: 201 |
how does dynamat or any sound deadening react with any leaks? (Thinking more footwell if they get damp and trap that moisture making things corrosion prone?)
10th May 2020 10:12am |
Fix the leaks first, it sticks, water ingress is not good, and it will lift up.
10th May 2020 10:22am |
Thanks.
Car currently has carpet rear and rubber matting up front - and really is not overly loud. However, I did notice engine noise almost from the bulkhead. Have you fitted any under bonnet dynamat and if so, huge difference? |
11th May 2020 5:18pm |
