Home > Maintenance & Modifications > Acoustic Mats vs Trad Sound Proofing with Carpet ?
Page 2 of 2 <12
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Yes, Dynamat and Dynaliner, AND a lead blanket 👍🏻 It cuts down 80% of the engine noise
Post #830508 11th May 2020 5:22pm
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
think I shall dynamat the bonnet !
Post #830535 11th May 2020 8:13pm
Dynamat alone doesn't really do much on a Puma bonnet. It's purpose is to add mass and reduce resonance but the Puma bonnet is already quite stiff. It has more of an effect on older bonnets.
I'd suggest that the biggest bang for your buck with this stuff is the rear floor and wheel boxes followed by the roof, especially if paired with closed cell foam. Improvements after that are incremental (seat box, doors, bulk head, etc) but the installation work becomes more difficult. Darren
Post #830597 12th May 2020 6:55am
StephenTD5
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
I haven't ordered anything for the roof yet because I need to replace the headlining so I figured I'd do it then.
For now I have ordered dynamat sheets for the bonnet, front footwell, seat boxes, rear cab and seat boxes. Plus the acoustic mat system for the front.
I'm hopeful this will make some reduction in noise Defender 90 Td5
BMW M4 Competition
Jaguar XJ6 Sovereign
Post #830959 13th May 2020 7:46pm
keith
Is there really such a difference doing the roof ? If the body and floor is already done.
Post #830976 13th May 2020 9:28pm
Yes, definitely.
 Darren
Post #830998 14th May 2020 7:39am
Lightwater
Australia
The Defender will have far greater acoustic issues than a Freelander, but there may be some information here you can adapt. I have pulled apart the car a few times adding more & more acoustic insulation & it has improved things a lot even though the car was pretty good to start with.
My gut feel for the Defender is use the butyl first & then a thicker foam Van Liner. Even then in key areas I would use a few layers of van Liner.
Under the bonnet I have used a few layers of engine bay liner as I felt one thickness simply was not enough.
Rather than repeating everything again, you may be able to utilise a few ideas from here https://www.freel2.com/forum/topic33026.html
 Visitor - Freelander owner
Post #841427 3rd Jul 2020 6:49am
wizzwas
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
LandRoverAnorak wrote:
Yes, definitely.
As LRA has done (which is probably the best way to do it), I've done my roof, only with the butyl pads, no foam though. Can't say I was blown away by the difference, but there was definitely a difference. Certainly made the stereo sound better.
I also have the MUD Utility Storage Panels in the back of my USW, they come with closed cell foam to go behind the panels, and they certainly made a difference too, not to mention being very handy and improving the look.
Mine is carpeted throughout and it's acoustic mat-backed carpet and although I've not taken it out to compare I imagine it does a half decent job too.
In fact, I'd love to know if full carpet is a factory option, if anyone can tell me? I've not seen a USW that's carpeted even in the load area before. And where can I get more?
I went for Noico butyl mats
https://www.amazon.co.uk/gp/product/B00URU...&psc=1
Good reviews, good price, does what it's supposed to and after doing the roof and rear panels I've still got a whole sheet left over.
Post #841870 4th Jul 2020 10:20pm
Page 2 of 2 <12
