Home > Technical > Removing trailer socket?
Green Machine
Could somebody tell me how easy it is to remove a standard 7-pin black trailer socket? I'm guessing it has a multi-plug into the main wiring loom somewhere? Is it just a case of unplugging it and pulling the wiring through? It seems to run inside the O/S chassis rail.
I removed my towbar years ago because I have no need for it, but the trailer socket was left in-situ. Now doing a refurb of my rear crossmember and the socket is in the way and had the thought 'why don't I just remove it?'.
Any assistance appreciated! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #826972 22nd Apr 2020 8:07am
90 Dreamer
if its the same as a Puma then there is a multi-plug up behind the OS rear light, accessed from the wheel arch by removing the plastic mud protector..........
Post #826973 22nd Apr 2020 8:10am
jst
It should go to a multi plug up behind the plastic crud guard where the light fittings are, above crossmember on os, if it's a genuine one.
On a 110 there is a multi plug by the filler.
If its aftermarket it sill be spliced in somewhere. Inside behind brake light possibly on os?
Just trace the wires back Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #826974 22nd Apr 2020 8:11am
hank
If it's spliced or the mulitplug is crudded solid you could secure it up out of harms way with cable ties > 110 XS Double Cab
Post #826981 22nd Apr 2020 8:33am
Green Machine
Thanks - will go investigate! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #826990 22nd Apr 2020 9:23am
jst
Its here
90 in today so took the opportunity to get a photo.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #827022 22nd Apr 2020 2:12pm
Green Machine
Many thanks JST - much appreciated Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #827258 23rd Apr 2020 6:06pm
