Home > Technical > Removing trailer socket? |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2141 |
if its the same as a Puma then there is a multi-plug up behind the OS rear light, accessed from the wheel arch by removing the plastic mud protector..........
22nd Apr 2020 8:10am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8009 |
It should go to a multi plug up behind the plastic crud guard where the light fittings are, above crossmember on os, if it's a genuine one.
On a 110 there is a multi plug by the filler. If its aftermarket it sill be spliced in somewhere. Inside behind brake light possibly on os? Just trace the wires back Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Apr 2020 8:11am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2295 |
If it's spliced or the mulitplug is crudded solid you could secure it up out of harms way with cable ties > 110 XS Double Cab
22nd Apr 2020 8:33am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Thanks - will go investigate! 2005 Td5 | 90 Station Wagon | Tonga Green
22nd Apr 2020 9:23am |
Its here
90 in today so took the opportunity to get a photo. Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Apr 2020 2:12pm |
Many thanks JST - much appreciated 2005 Td5 | 90 Station Wagon | Tonga Green
23rd Apr 2020 6:06pm |
