Home > Maintenance & Modifications > LOF Powermaster Install tips
Page 1 of 3 123>
Co1
Ordered one yesterday. Installation takes 25mins says the website, but given that it took me a couple of weeks wrestling the assist spring into position, has anyone got any tips on this?!!
Post #824519 11th Apr 2020 7:53am
ibexman
Do a search
Post #824521 11th Apr 2020 8:06am
ibexman
Double post
Post #824522 11th Apr 2020 8:06am
Co1
Thanks!!
Did that, didn’t find a great deal of detail other than reviews. Hence the post.
Post #824528 11th Apr 2020 8:41am
hank
Do you mean the powermaster (master cylinder) or the powerspring (pedal spring)? Perhaps you bought the kit containing both parts?
Your post suggests it is the spring you are having trouble with, have a read through the following thread https://www.defender2.net/forum/topic66507.html > 110 XS Double Cab
Post #824530 11th Apr 2020 8:56am
Mo Murphy
Remove the clutch pedal box to change the master.
Straightforward mechanical job, bleeding the system can be challenging for novices.
HTH
50 Shades of Pennine Grey
Post #824537 11th Apr 2020 9:28am
donmacn
^^^ That's what I did - pedal box out. Makes it a breeze really.
Mo - what do you mean it can be challenging to bleed for novices? Mine is bled, and working, but wondering if I've missed something, as I can have novice tendencies on occasion....! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #824544 11th Apr 2020 10:00am
Co1
Cheers guys, much appreciated. It is the powermaster I was talking about. I fitted the spring a while back.
Post #824555 11th Apr 2020 10:24am
Mo Murphy
Don,
Challenging in respect that it can be difficult to bleed completely on first attempts. Once you've done a couple you know what to expect. I find driving it for a while helps, some like to hold down the pedal overnight or reverse bleed.
Post #824558 11th Apr 2020 10:33am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Unbolt the slave cylinder, hang it downward with the bleed screw open ,
Press the pedal down and keep it there , keep topping up the fluid , shouldn’t be far away by then Thumbs Up
Post #824574 11th Apr 2020 12:29pm
donmacn
Thanks - not aware I've had an issue really, but I did this recently as I had to change the pipe. All seems to be working fine - I was just curious.
Co1 - you'll love it when it's fitted. I have both the spring, and the powermaster, and the net effect is such an easy pedal. Donald
in the past..
Post #824632 11th Apr 2020 6:48pm
Co1
HTH
Mo
I don’t know what the hell im doing wrong, but I can’t even get the mats back to access the bolts for the pedal box!! LOF website reckons this is a 25 minute job!! I can only assume they’ve never don’t it on a puma! Once the pedal box is loose, does it even fit past the brake lines?
Post #826176 18th Apr 2020 12:14pm
Mo Murphy
Co1,
The mats do get in the way !
I'm not sure how mats are secured in the puma. I done it up to TD5 and the rubber mats are secured by a metal strip across the bottom of the dash/ top of the footwell. The screws on the strip need slackening to allow the top edge of the rubber to be eased out and pulled down. This will then allow the pedal box bolts to be accessed.
Be patient, work methodically. It's not difficult but does require thought especially if you haven't done it before.
HTH
Post #826181 18th Apr 2020 12:26pm
Mo Murphy
If you reach an impasse, step away, have a cup of tea, then have another look Wink
Post #826182 18th Apr 2020 12:29pm
Co1
Cheers Mo. Not sure I’ve got enough tea bags!
Post #826184 18th Apr 2020 12:36pm
Page 1 of 3 123>
